This forum is awesome. I've learned so much and got so much inspiration from you all. Here's a question for the engineers in here.
Charmac builds their Stealth line of trailers with "S" shaped channel steal studs and aluminum skin with a strip of butyl tape between the metal studs and the exterior skin. They say the butyl helps with water resistance. They use the #2 square head self driving screws to attach the skin.
I drive my trailer about 300 miles per week over state roads, some of them bumpy. In the last 6 months, I've put probably 7-10K miles on the trailer. I've noticed that the self drilling screws on my skin are backing out. I can, of course, tighten them back up as needed. But due to the nature of the aluminum and the relatively thin steal studs, I forsee this being a problem in the long term. The screws will get looser and looser every time I tighten them.
So I called Charmac to see what they recommend I do. They gave me the answer which I kind of expected; try blue loctite. However, I'm a little concerned about using blue loctite for this application. I think loctite is meant for situations where there's a lot of screw-thread to substrate contact (that is, something like threading a lug nut onto a wheel, or threading a nut on an engine bolt). In this application, there is very little exposed screw thread.
1) has anyone here experienced this?
2) what product would you suggest that I try on my screws? I was thinking maybe one something like a construction adhesive, or a polyurethane glue like Gorilla glue. Ideas?
Thanks!
