by hankaye » Sat Nov 22, 2014 10:35 pm
Spotman, Howdy;
Have you thought about some good old fashioned Rubbing compound?
Get on of those squeeze bottles that you get katsup or mustard in, put
1/8cup of compound in it and fill 3/4 full with water. Shake it very well,
until all of the compound is dissolved. Squirt a small amount onto the surface
and rub in by hand a buffing wheel wight just rub the paint right off.
Keep to 3' X 3' squares. When you finish one side go back and use a soft
clean rag ( I prefer towels cut-up), to remove. I used to do 1 Cessna 150 a
night with that solution when I was a teenager and worked at the local airport.
Skins are about the same (0.030"), and the paint isn't that much thicker on one
as opposed to the other.
hank
hankaye on Sun Nov 23, 2014 10:50 am, edited 1 time in total.
