Mike S wrote: I push the unit out when it's in use and pull it in for travel and storage.
I plan to modify the set-up this summer to allow me to operate the unit without pushing it out. I want the ability to run it without pushing it out.
aztrooper wrote:I'm getting the GE 6,050 BTU Window Air Conditioner with Remote Model AEL06LS from Home Depot when they come back into stock. The calculations I checked on mine, a 7X18 V nose said 5500 watts. I'm just going to mount it inside, line the "tunnel" with aluminum for the water to drain onto and down through a hose and exit the exhaust out the side that will be covered with a louvered vent cover so it will look like a refrigerator exhaust. I am going to put a vent on the roof above it so it gets lots of outside air. The vent will be the normal RV type vent with rain cover.
JWG wrote:Mike S wrote: I push the unit out when it's in use and pull it in for travel and storage.
Mike S, I am curious as to why you are changing from the slide out option to the inside mount. I might be headed the wrong direction with the slid.
Any insight you can share is appreciated. Thanks
