Page 1 of 3
Guardcompany's Conversion
PostPosted: Mon Apr 20, 2015 2:56 pm
by guardcompany
Hello all. Long time reader and first time poster.
I got a new 2014 Pace 6x12' last year and haven't had the time to touch it. So I'm really excited to finally be starting on this project.
I got the RV door and the 6'6'' height model. I had a leak caused by a bad door seal so I had to have some warranty work done. I have stained the ramp door and did the axel flip kit.
My first real projects are as below with some questions. Thanks and it's been great watching your builds come along, excited to get mine going.
1. Fantastic Fan. I'm about to order one and noticed they have "Retail" and "OEM" versions (http://www.fantasticvent.com/fan-tastic ... -fans.html and http://www.fantasticvent.com/fan-tastic ... -fans.html) Since this is going into a new construction does it matter? I'm just looking for the basic 3 speed reversible one, nothing fancy.
2. I would like to put a window in the door. What does everyone think of Edwin windows? (http://easyrvwindows.com/rv-entry-door.html) Worth the price?
3. Wiring. Need to map out all my wiring and start ordering my fuse block and figure out how I want to wire everything. I'm doing to keep everything DC with the except of one inverter.
3. Insulation.
Re: Guardcompany's Conversion
PostPosted: Mon Apr 20, 2015 3:13 pm
by lrrowe
Welcome guardcompany,
As you probably gathered from the posts here, you should have a great time with your project.
I did not look at all the specs for each OEM vs. Retail fan, I can only assume that they are the same per se. I would search the internet, find the one that has the features you want at a price you like and go with it.
My trailer door came with a window, so I did not have to add one. The one you listed looks pretty straight forward and should work for you. My caution would be to get comfortable with whether there are ribs or something in the area you want to add it. My first instinct is to see if I could open it up, look at the construction and add the ribs or reinforcement you need. I think mine is foam filled.
PostPosted: Mon Apr 20, 2015 5:25 pm
by Spotman
Guardcompany, let the fun begin. A lot of knowledge and some fine work done on here, you should be hearing soon. Post where you are located. You may be near some one who has done it before, enjoy this site and some of us will see you out somewhere.
:pictures: :pictures: :pictures: Keep posting those pics on your progress. :pictures: :pictures: :pictures:
Bob
PostPosted: Mon Apr 20, 2015 6:14 pm
by guardcompany
Thanks everyone. I figured out the Fantastic Fan model I wanted and went with the 2251 (http://www.amazon.com/gp/product/B00IKMC6M0) the old model number for it was 4000R. Their model numbers are confusing, changed and a lot of online vendors don't list the correct model. So we will see what I get ha, which is why I got it through Amazon. I'm gonna read through a bunch of the new build threads on here before I ask more questions as I think a lot of them have been answered already.
PostPosted: Wed Apr 22, 2015 5:48 pm
by professorkx
Yes, pictures, pictures pictures. :applause:
PostPosted: Sat May 02, 2015 11:53 am
by guardcompany
Update 5/2/15:
Just got the Fantastic Fan frame built and the fan in. Going to waterproof and screw it down today. Here's a lot of photos since you asked. Thanks to my brother for laying out the frame, welding and use of his shop. It's so much easier than the driveway!
Next up is insulation and wiring. I have a PD4045 coming next week.
Also will be installing a backup camera for the back up my truck for hooking up and one of the back up the trailer:
Monitor: http://www.amazon.com/gp/product/B007SLDF7O
Cameras: http://www.amazon.com/gp/product/B00GSFIJS6
Wireless for the trailer camera: http://www.amazon.com/dp/B008Z9E4DW
PostPosted: Sat May 02, 2015 12:33 pm
by Rainier70
:thumbsup: :applause:
PostPosted: Sat May 02, 2015 3:04 pm
by Spotman
PostPosted: Sat May 02, 2015 5:07 pm
by guardcompany
Putty Tape
In the process of screwing it down via 1'' hex self tappers
Dicor self-leveling lap sealant
PostPosted: Sun May 03, 2015 12:08 pm
by Doublacola
Nice job! That shouldn't leak.
PostPosted: Sun May 03, 2015 2:05 pm
by lrrowe
guardcompany wrote:Update 5/2/15:
Boy do I sure do envey you and that door height. To bring one's trailer inside to work on is to die for. (well, maybe not that drastic, but it is great!)
PostPosted: Mon May 04, 2015 10:53 am
by professorkx
Excellent. Keep those pictures coming...
PostPosted: Wed May 06, 2015 1:12 am
by rebapuck
And a brother who welds!!
PostPosted: Wed May 06, 2015 3:56 pm
by CGRotorhead
PostPosted: Sun May 24, 2015 1:00 am
by guardcompany
Update 5/23/15
Got most the insulation done. Thanks to all the threads I was able to answer all my questions by searching.
Pictures...
Getting the wood off the walls:
Running my electrical:
Ceiling insulation is done:
Finishing hanging 1/8 sanded plywood ceiling:
Walls going in:
One wall done:
18 gauge backing going in so stock plywood can run together. No more ugly joint braces:
Bottom sheet in:
More pictures soon...
