Rhino / Herculiner / Monstaliner on the CT Roof?
Postby RetchedOne » Wed May 27, 2015 9:23 am
Anyone ever rhino line / Herculine / Monsta line the roof of their cargo trailer???
Mine isnt leaking, but i'd love to get rid of the ugly curved metal and permanently seal it up after the AC and vents are cut in.
What about the sides (sides have the painted aluminum)
I know it wont help weight or mpg...
They make some cool colors in the monstaliner that would look soooo much better than the dirty white my trailer has become.
RetchedOne
Images: 9
Re: Rhino / Herculiner / Monstaliner on the CT Roof?
Postby khigh » Wed May 27, 2015 1:54 pm
I've been considering this as well.
I want it for four reasons - to extend the life of the roof, to doubly seal anything I add like solar, to mitigate rain noise, and to make it the most reflective possible (white? Is there silver?) color to reflect heat.
I've heard it's pretty heavy, but haven't done the math.
I'm interested in hearing any downsides also
khigh
Postby Rainier70 » Wed May 27, 2015 2:05 pm
I would go with something like Henry's Elastomeric Roof Coatings that are solar reflective. They are designed for roofs to seal as well as to reflect sun and heat. I haven't used it yet, but lots of people swear that it really helps.
Rainier70
Images: 244
Postby RetchedOne » Wed May 27, 2015 2:30 pm
My other fear... What if it doesn't stuck to aluminum... I'll have a mess.
RetchedOne
Images: 9
Postby wtcreaux » Wed May 27, 2015 9:35 pm
I used this......
http://www.homedepot.com/p/Henry-687-4-75-Gal-Enviro-White-Roof-Coating-HE687406/202091034
Looks like this on the roof....
130230 130629
I put 4 coats on a 6x12 V-nose and only used about ⅓ of container. After the 1st coat, I could already tell the difference - before, couldn't touch the roof due to heat; after the 1st coat, I could feel the coolness of the paint on the roof. The directions state at least 2 coats, perpendicular to one another......
wtcreaux
Images: 211
Postby RetchedOne » Wed May 27, 2015 10:15 pm
Did it stick ok to the aluminum? Doesn't scratch easily? Edges ok?
RetchedOne
Images: 9
Postby aggie79 » Thu May 28, 2015 8:58 am
I don't think truck bed liner will adhere to plastic. So before the installation of the liner, you'd have to remove roof vents, A/C units, vents, etc. and reinstall and seal them after the liner has cured.
Postby RetchedOne » Thu May 28, 2015 9:00 am
aggie79 wrote:I don't think truck bed liner will adhere to plastic. So before the installation of the liner, you'd have to remove roof vents, A/C units, vents, etc. and reinstall and seal them after the liner has cured.
I would agree with that, it will look better too!
RetchedOne
Images: 9
Postby hankaye » Thu May 28, 2015 9:09 am
RetchedOne, Howdy;
RetchedOne wrote:Did it stick ok to the aluminum? Doesn't scratch easily? Edges ok?
Here's the Manufacturer's Data Sheet for the 885 product.
http://us.henry.com/fileadmin/pdf/curre ... chdata.pdf
When you look in the usage section they show a very thick and an even thicker
application. For the 5 gallon pails they show an application thickness that is much
more CT friendly, Of course, any application will only adhere as well as the surface
is prepped. See pg. 2.
hank
hankaye
Postby Gunman9 » Fri May 29, 2015 8:40 am
Has anyone tried these?
http://www.lowes.com/pd_12034-29-5175-A ... 1&Ntt=roof
http://www.homedepot.com/p/Henry-0-90-G ... 5yc1vZapzz
I may try the Henry stuff from Homedepot but only probably need a gallon what it sounds like.
Gunman9
Postby hankaye » Fri May 29, 2015 8:57 am
Gunman9, Howdy;
hmmm Limited Life time warranty vs. 1 year limited Warranty ... :thinking:
Application temps, 36* vs. 60* ... :thinking:
Appearance, smooth White aerodynamic vs. rough siliverish not so aerodynamic ... :thinking:
hank
hankaye
Postby Gunman9 » Fri May 29, 2015 9:04 am
hankaye wrote:Gunman9, Howdy;
hank
Lol I understand what you are saying. I posted the reply before I searched for what was in stock at my homedepot. I'm gonna go with the henry stuff.
Gunman9
Postby wtcreaux » Fri May 29, 2015 4:14 pm
The first coat was a bit "sticky" as I learned how to do it.
Lessons (no particular order)
* Instead of dipping your roller into the bucket, take a smaller bucket and scoop onto roof, then spread it out.
* cleans up with water nicely (I didn't use painter's tape, just a wet rag to clean edges)
* it says allow for a day before putting second coat on.......depending upon humidity, wait AT LEAST 24 HOURS
* THICK is OK
* Damp surface is OK (actually encouraged) for application
wtcreaux
Images: 211
Postby khigh » Fri May 29, 2015 8:05 pm
* THICK is OK
Thanks for those tips. I've been researching and researching and have decided on the Enviro-White myself once I get all my roof bits figured out - the solar and whatnot.
One more question about the wiping and not taping. What keeps it only on the roof when you get out to the edge of the trailer? Do you let it run over the side and then go around and wipe it up? Or does it pretty much stay on the horizontal as you roll out past the edge without dripping down on the vertical?
How much did you use? I don't want a 5 gal, but not sure I can get away with 1 gal on a 6x12 deep V
khigh
Postby wtcreaux » Fri May 29, 2015 8:43 pm
I could only find the 5 gallon.......used about ⅓ of it - 4 coats on a 6x12 V-nose, flat roof. it's pretty thick, don't thin it. Water clean-up
wtcreaux
Images: 211
Users browsing this forum: Google [Bot] and 3 guests
