I just purchased my soon to be new castle.
Postby akula1 » Sat Sep 05, 2015 9:26 pm
i just purchased a 2011 Wells Cargo V-nose 7 X 14. It is in great shape all around. I have to move from Utah to Arizona, and then the conversion begins.
On my inspection I noticed surface rust along a lot of the bottom, should I jack it up and scrape, and paint, or take it somewhere and have it removed, and have the bottom sealed?
Second question is, I'm planning my layout, and trying to plan my electrical layout. Do you notch the interior wall to run the wiring in the walls? Or do you drill through the metal support beam?
Thanks!
John Serenita
Owner of a 7 X 14 Cargo Camper
akula1
Re: I just purchased my soon to be new castle.
Postby Padilen » Sat Sep 05, 2015 10:52 pm
There are a lot of products that convert rust to a sealed paintable finish. Might be a easier way to take care of your rust than scrapping.
Padilen
Postby CoventryKid » Sun Sep 06, 2015 10:29 pm
John:
When I bought my CT, I removed the interior plywood so I could insulate. I installed 1" rigid insulation between the aluminum ribs. Then I added 3" wide strips of 1/2 plywood to each rib as a thermal break. I added 1/2"rigid insulation between the strips. I ran my 12V wiring in the 1/2" insulation space. I then re-attached the interior plywood, screwing it to the plywood strips.
Because I converted our 7x16 V-nose CT to a travel trailer, I ran my 110v wiring on the surface of the interior plywood (inside cupboards, etc.) and/or through the interior walls.
I started to document my build but did not update my post. My build website: http://www.tusker-international.com/1-trlr.html
Hope this helps!
Doug
Vancouver Island, BC
CoventryKid
Images: 130
Postby akula1 » Sun Sep 06, 2015 10:51 pm
Thanks for the input and tips.
I will check out your build. :D
John Serenita
akula1
Postby wanabxtrm » Mon Sep 07, 2015 12:37 pm
I went a similar route. Rigid foam between the joists, then 1/2 NM electrical conduit, and 3/4 insulation board atop the the face of the walls, then a second 3/4 layer of foam to cover it all with occasional 1x4's where I need to hang/ attach things to the wall. (1x is actually 3/4" and 1/2 NM tubing is roughly 3/4" in exterior diameter so it all flushes up). Good luck.
wanabxtrm
Postby Prem » Mon Sep 07, 2015 5:16 pm
Cheapest, easiest and least expensive fix:
Paint NAVAL JELLY (any hardware store) on the rust. Let dry and paint with oil-based enamel. GREAT FOAM in a spray can (polyurethane) is even more durable and waterproof over time, but messy and it expands. You can knock the expansion down with a stiff brush or a putty knife while it´s still gooey. Paint peels on it.
:beer: FWIW,
Prem
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby OverTheTopCargoTrailer » Mon Sep 07, 2015 6:10 pm
WOW , I'm sorta really amazed about 4-5 people here are now using the OTTCT , double wall, floor, ceiling insulation method.
Prior the standard was 3/4" to 1" walls and ceilings only. Now we are up to 2"+ walls, floor & ceiling. I'm still not seeing to much about doors yet ?
I'm working on top secret V3.0 now - I did some beta testing already with excellent out of the park results. The day may come where we will all be driving around in a trailer , heated and cooled with 500 watts in solar on dare I say lithium batteries & mini splits 20 years from now :lol:
Ottct
Postby hankaye » Mon Sep 07, 2015 6:25 pm
akula1, Howdy;
Prem wrote:Cheapest, easiest and least expensive fix:
:beer: FWIW,
Prem
Prem, IMO, left out a step, you need to stop the Navel Jelly's rust eating action. That requires water.
Wash it off completely, allow the surface to dry ...... then proceed as he recommends.
The Navel Jelly also imparts a protecting coating (my experience), and allows an excellent bonding
surface for the new paint or apply the "Great Foam" directly to the surface. Each layer only bonds
to the surface it touches. Poorly applied preparations don't stay stuck very long or well.
hank
hank
hankaye
Postby akula1 » Mon Sep 07, 2015 6:51 pm
Overthetop, and all the others, these will definitely help me.
Do you notice a significant difference between the single 1" rigid insulation, compared to doing the 1 1/2"+ insulation?
What would you do different now with your build?
Thank you!
John Serenita
akula1
Postby OverTheTopCargoTrailer » Mon Sep 07, 2015 7:37 pm
I have between 2-5" insulation, cooling my 7 x 18 trailer with around 200 watts per hour of run time. One 1/6 to 1/8 power that standard rv uses.
PS excellent job on your build
Postby CoventryKid » Mon Sep 07, 2015 10:50 pm
Re your question re 1" insulation vs 1 1/2".....and why I went with 1 1/2".
I knew from reading this forum that just adding insulation between the 1" ribs was not going to solve the problem of screw heads sweating - no thermal break. So I knew I was going add a thermal break (the 1/2" plywood strips on the ribs). It was a no-brainer to add the extra 1/2" rigid insulation. By the way, I sealed all the gaps with metal-foil tape.
I've had no problems with condensation. And the odd time the temperature has dipped, our little electric heater has no problem raising the inside temperature quickly.
Hope this helps!
Doug
CoventryKid
Images: 130
Postby Prem » Tue Sep 08, 2015 4:57 am
Hank,
Naval jelly is an acid. City tap water is an acid.
I let the naval jelly dry then wire brush it if it is thick in places and then paint it. The dried stuff is bonded to the metal. I call that primer. And it´s pourous, so even the oil-based enamel sticks to it longer. (But I sold those trailers. :R )
Nothing is forever. . .except an all-aluminum trailer. :lol: 8)
My goal...
Prem
Images: 144
Postby Padilen » Tue Sep 08, 2015 8:19 am
Aluminum corrodes but last a lot longer than steel.
Padilen
Postby aggie79 » Tue Sep 08, 2015 8:35 am
akula1 wrote:i just purchased a 2011 Wells Cargo V-nose 7 X 14. It is in great shape all around. I have to move from Utah to Arizona, and then the conversion begins.
Congratulations! :applause: I hope to join the CTC club in the future. Please post lots of pics for us wanabees.
akula1 wrote:On my inspection I noticed surface rust along a lot of the bottom, should I jack it up and scrape, and paint, or take it somewhere and have it removed, and have the bottom sealed?
Assuming that your rust is primarily surface rust, I'd lightly wire-brush the frame and then use a rust converter product system like POR-15 or Rust Bullet. I used Rust Bullet on my teardrop frame and it is a great - although a little expensive - product.
Postby McDave » Tue Sep 08, 2015 1:27 pm
Surface rust in the desert? We call that "Patina". Adds a certain Je ne sais quoi. Just charge a little more if/when you sell.
Don't sweat the petty things, pet the sweaty things.
Just sayin' .......
McDave
Images: 412
