window AC vs portable AC
I see a bunch with window ACs. Is there a reason why people are choosing them over the portable ones? Seems portable with a 4" hole would be an easier install. Am I missing something?
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
MtnDon wrote:Single hose portable units have a built in inefficiency. The single hose blows hot exhaust air out. That air must be replaced with other air. Other air from the exterior. Where is is hot and/or humid, otherwise we might not need to be running the A/C unit at all.
A window mount A/C does not do that. It recirculates the interior air and has a separate air loop for moving the heat to the outside. Shadowcatcher's hack takes advantage of that.
Fir real high efficiency and quiet look into a mini split. $$$$ but top rung.
[/quote]Mike S wrote:
A mini-split would be really cool but I don't know why I'd spend 10x more $$ for A/C.![]()
Well that answer is really easy:
1.) I'm really crazy
2.) I have endless money.
3.) It is almost 100% silent 35db
4.) Cools to 118F
5.) Heats to 17F
6.) Runs 100% on solar
7.) Uses less then 200 watts per hour.
8.) All RV experts say it's impossible to run on 100% solar.
AND NOBODY ELSE GOT ONE
