Anti sway bar
Anti sway bar
Postby Spotman » Wed Sep 09, 2015 4:34 pm
I ddid some searching, but.... I have a 7x14 V-nose cargo trailer and the tounge is very short, can't even mount an LP bottle on it. :thinking:
My question is, would an Anti Sway Stabalizer Bar work a lot better than just towing with my truck hitch? I have been towing all kinds of trailers with longer tounges with no problems. While I tow the Cargo trailer, it seems to lag and feels like it struggles. No it's not the truck, it's a Tundra! Any thoughts and suggestions from those of you who have used a sway bar would be appreciated.
Thanks,
Bob
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
Re: Anti sway bar
Postby MtnDon » Wed Sep 09, 2015 5:07 pm
Spotman wrote: While I tow the Cargo trailer, it seems to lag and feels like it struggles.
I'm not sure what you mean by that? Anti-sway bars are supposed to help if the trailer wants to "wag the dog", so to speak. If that is the case an anti-sway setup could help.
Our CTC is a 6x12 deep vee nose, maybe much like yours as there is also no room in front of the point for a propane cylinder. (However I mounted one on the drivers side of the point, adjacent to the slanted wall. See it here. )
Ours feels about the same as any other trailer of comparable weight when towing. It tows dead steady everywhere we've been with it. If yours is built about the same way there may be insufficient room for an anti sway bar system. I could not easily fit one to ours.
MtnDon
Images: 24
Re: Anti sway bar
Postby lrrowe » Wed Sep 09, 2015 5:11 pm
Bob, you have seen my trailer and it towed great without one, so I am not one to help much with a CT. I have used them on a traditional camper and ended up with an impossible to control sway which resulted in this.
My point is that I still got into an uncontrollable sway with one. But who is to say that it was not my truck's suspension's fault, my connection of the sway bar, my driving skill or just something that I could not control. A logging truck (not the one in the picture) went by me fast at 55 or so and the wind just pushed me over to the road's edge.
I know this does not really answer your question, just wanted to share it with you.
Bob
lrrowe
Images: 439
Re: Anti sway bar
Postby Spotman » Wed Sep 09, 2015 5:22 pm
Don, thanks for your input. I have been following your pages and very impressed. Including all the builds you have accomplished and the great knowledge you have given to everyone who asks. I just think it might be that this is the heaviest/bulkiest rig I have ever towed and it just felt "very" different than the others.
Bob, Dang, Damn and Darn... you kept your truck and "trailer" upright after all of that! :?
I probably would have said, "that's enough towing for me"! :shock:
Bob
Spotman
Images: 241
Re: Anti sway bar
Postby lrrowe » Wed Sep 09, 2015 5:34 pm
Spotman wrote:Don, thanks for your input. I have been following your pages and very impressed. Including all the builds you have accomplished and the great knowledge you have given to everyone who asks. I just think it might be that this is the heaviest/bulkiest rig I have ever towed and it just felt "very" different than the others.
Bob
I think I was very very lucky. Especially since I had two young boys in the truck with me. I used up both lanes on one side of a divided highway trying to get the trailer back under control. Afterwards, I concluded that the base of the wood frame had weakened as the result of a flood one year that went up to the top of the frame. If that happened, that weakness may have been what allowed the RV body to flip off the frame and save our butts. But no, it did not scare me that much as I went out and bought a replacement weeks later
Bob
lrrowe
Images: 439
Re: Anti sway bar
Postby hankaye » Wed Sep 09, 2015 8:03 pm
Soptman, Howdy;
You might try reading up on these. Although i think they require
about 28-34 inches from the ball along the hitch frame for proper
installation.
If your trailer is feeling piggish then you might want to re-examine
your weight distribution within the trailer ... If the steering isn't
extra light you may have to much weight aft of the trailer axle.
hank
hankaye
Re: Anti sway bar
Postby Spotman » Wed Sep 09, 2015 8:24 pm
Hanaye, thanks for the info, will investigate hopefully tomorrow.
Spotman
Images: 241
Re: Anti sway bar
Postby hankaye » Wed Sep 09, 2015 10:30 pm
Spotman, Howdy;
Spotman wrote:Hanaye, thanks for the info, will investigate hopefully tomorrow.
Sorry forgot to include the link, http://www.equalizerhitch.com/
and they have a special doc. for V-nosed trailers;
http://www.equalizerhitch.com/pdf/v-nosetrailers.pdf
hank
hankaye
Re: Anti sway bar
Postby Alan_H » Wed Sep 09, 2015 10:39 pm
I was thinking weight distribution as well. Make sure you have at least 10% of your total weight as tongue weight.
Alan_H
Re: Anti sway bar
Postby Spotman » Thu Sep 10, 2015 7:29 am
hankaye wrote:Spotman, Howdy;
hank
I thought something was missing, I was going to Google for info!
Spotman
Images: 241
Re: Anti sway bar
Postby aggie79 » Thu Sep 10, 2015 11:58 am
The Andersen weight distribution / anti-sway hitches don't use the torque arms to distribute weight so the bracket attachment point is shorter than most WD hitches. http://www.andersenhitches.com/Catalog/andersen-nosway-weight-distribution-hitch.aspx
If I do a CT conversion, I will get the Andersen setup.
Re: Anti sway bar
Postby Mike S » Thu Sep 10, 2015 12:32 pm
I have essentially the same set-up as you Bob. The only difference is that mine isn't a V-nose, and therefor has a longer tongue. But how would the tongue length make any difference in towing? What matters is how much of the trailer is in front of the axles, right? I've never towed with a WD hitch or an anti-sway bar so don't have much to compare to but IMO you're fine without them. I tow over winding mountain roads and passses, interstates, in snow, and in high wind situations on a regular basis. I've never experienced any kind of sway or instability with my trailer/truck combo. It seems to tow fine with the standard ball hitch. It's pretty easy to load a cargo trailer with too much weight in front and therefor create instability so be aware of that. Shoot for 10-15% of your trailer weight on the tongue for best handling.
2013 7 x 16 Charmac Stealth CT , deep in conversion process :)
http://www.tnttt.com/viewtopic.php?f=42&t=66412
2011 Toyota Tundra, 4x4, Double Cab, 5.7L
Mike S
Images: 54
Re: Anti sway bar
Postby lrrowe » Thu Sep 10, 2015 12:34 pm
At $450 for the kit, it is not inexpensive. But to help reduce the dreaded sway and results like I had, it may well just be worth it. I like the simplicity of it. It appears that there should be no pinched fingers like I used to get with the traditional style. And it looks good also.
Bob
lrrowe
Images: 439
Re: Anti sway bar
Postby Spotman » Thu Sep 10, 2015 12:35 pm
You guys are a great wealth of information on here. I will check weight distribution in the future. There really is no much weight in there when I do tow?? Most goes in my truck.
Spotman
Images: 241
Re: Anti sway bar
Postby hankaye » Thu Sep 10, 2015 8:41 pm
Spotman, Howdy;
Another thought came to me when I re-read your initial post. When you mentioned
"While I tow the Cargo trailer, it seems to lag and feels like it struggles. No it's not
the truck, it's a Tundra!"
Well it may be the length of the 2 wheel bases. Is your's a short wheelbase? Here's a
few items to read to see if anything they have to say rings a bell ;
http://www.streetdirectory.com/travel_g ... ility.html
Interesting series of articles (pages);
http://www.synthx.com/articles/trailer-design.html
Here is what I used for my search Wheelbase effects on handling when towing
Hope it helps or gives some insight.
hank
hankaye
