FlyBye wrote:I also have noticed a wide range of pricing among trailers...
On the screw-less aluminum sidewalls, how are the sidewalls attached? (welded?) They do look a lot nicer!
The sidewall aluminum panels are held on with Very High Bond (VHB) tape. It's like the double-sided foam tape that you get at the hardware store but thinner. The tape is applied to the framing and adheres the aluminum sheeting. Each successive sheet overlaps the prior sheet. It doesn't sound like it would hold but it is a method used to skin buses, passenger trains, etc., so it must be durable.
FlyBye wrote:The framing/bracing for optional windows, would definitely be a plus in my book.
Although I can weld (kind of, sort of) I don't trust my welding in close proximity to the aluminum sheeting. The downside of having the factory frame the opening is that you must get exact dimensions of what you want them to frame for and you must know exactly where you want the framing. This can be tricky if you don't have the windows and vents "in hand" before you order the trailer. If you do it yourself, you can adjust accordingly and on the fly. Others may disagree, but one option that I have considered to frame the openings myself is to use angle iron "clips" and structural pop rivets and/or self-tapping screws to frame the openings.
FlyBye wrote:As far as the facility tour is concerned, that obviously would be wonderful if I lived within a reasonable drive. I don't so I'm in contact with one facility that does deliver reasonable close to my neck of the woods, to see if I might be able to inspect any trailer that they have made (regardless of the size).
That's what I have done. Some retailers seem to be willing to help with a custom order; others aren't interested at all. All, though, have let me crawl around, over and under the trailers to take a look at them.
FlyBye wrote:I've read where many on this forum have chosen or desire to go the aluminum route. I can see and understand many of the benefits, however I plan on going the steel route even though it will be heavier and have the rust factor.
All aluminum is certainly the Cadillac of cargo trailers. Weight savings is the primary benefit. It's hard to get an apples-to-apples comparison, but I figure the weight savings is about 300-400 pounds for an all aluminum compared to a steel frame, aluminum skinned trailer.
FlyBye wrote:I hope to get all my "ducks in a row" where I can confidently make an order sometime early spring with the desire of it being built and used by next summer and early fall. As much as I enjoy tent camping, I'm looking forward to retiring the tent! :-)
A few years back we moved from tent camping to teardrop camping and it was a huge upgrade. Now we're looking for something with an indoor toilet and shower and a place we can stay during inclement weather. (We actually prefer to go camping in the winter when most of the state parks here are little used.)
