Ventilation?
Ventilation?
Postby makevx73 » Fri Oct 30, 2015 8:57 am
Ok, I'm hoping to get a bit of advice on this...
My trailer came with the high front and low rear plastic "vents" installed. (Like these: http://www.etrailer.com/Enclosed-Traile ... -AVT2.html )
I'm thinking of using the front one for a vent for the bathroom area by using a computer fan and some pvc piping. These fans usually are about 50-60 cfm, although are available to about 250 cfm..
I'm thinking of doing the usual roof install on a fantastic or maxxair type fan, but wondering if that much airflow is really needed?
My reasons for wondering are:
- Not wanting to cut a whole in the roof if not needed.
- If I installed 2 computer type vans - reversible, I could "double vent" air entering from windows or have one pulling air in and one pulling air out when the windows were closed.
- I will have A/C installed for use if it's too warm for the fans so I don't think I need a large amount of air flow.
- The computer fans draw almost nothing power wise and are very quiet. Additionally, a small solar panel could be added to run a fan while in storage to keep dampness from setting in.
My idea would be to recut/enlarge the holes from the vents and install a flange that could be capped off while driving to make them water tight when not in use. Unscrew the cap, screw in a elbow with bug screen installed. Bug proof, rain proof, low power and quiet...
Let me know what you think?
EZ-Hauler 7x12, single axle, V front, sloped roof, all-aluminum, barn doors.
makevx73
Images: 5
Re: Ventilation?
Postby walkrdg » Fri Oct 30, 2015 9:44 am
While I was doing some research before ordering my trailer, I ran into a comment (I can't find it now) by a woman with a newly converted, that said on their first camping trip they traveled on some dirt roads. When they arrived at their camp, they found the trailer inside covered in fine dust - in and on everything. They weren't able to clean up the mess until they got home. She recommended either leaving the vents off, or having some that will close off entirely.
I opted to leave the vents off when I ordered. I've had no sign of dust inside. I did, however have two windows installed along with one roof vent. I generally have the roof vent open a couple of inches nearly all the time with a Max/Air cover installed. No rain inside, either.
Just something to think about.
Dave
walkrdg
Images: 7
Re: Ventilation?
Postby makevx73 » Fri Oct 30, 2015 12:34 pm
walkrdg wrote:While I was doing some research before ordering my trailer, I ran into a comment (I can't find it now) by a woman with a newly converted, that said on their first camping trip they traveled on some dirt roads. When they arrived at their camp, they found the trailer inside covered in fine dust - in and on everything. They weren't able to clean up the mess until they got home. She recommended either leaving the vents off, or having some that will close off entirely.
Dave
Thanks,
Yep, the vents don't seem to have many "positives" for a camper build. That's why I'm trying to put them to some good use. I would never have gotten them if I ordered a special order myself. My trailer was a canceled special order from somebody else. Had most of what I would have ordered and the price was good... Mine now :)
The front upper one will be a vent for the toilet for sure. The rear lower will probably end up as a vent for a fridge. I may as well keep the heat behind the fridge from warming the trailer... When my galley is closed up.
Open a few inches? How's that in fan speed? Low, medium, high?
I'm trying to figure out how much airflow most people rely on their overhead vent/fan to move to be useful?
makevx73
Images: 5
Re: Ventilation?
Postby walkrdg » Fri Oct 30, 2015 1:38 pm
Seems like the way you're going about it, you'll solve it. And, you'll be disrupting the "flo-thru" in the process.
Good luck,
Dave
walkrdg
Images: 7
