Page 1 of 3
Roll on bed liner for flooring?
Posted:
Wed May 18, 2016 9:00 pm
by funengineer
Has anyone used DIY bed liner in their cargo trailer conversion for flooring? I haul motorized toys in mine and also camp in it so I need something that can stand up to oil, gas and rubber tires and still be clean enough to camp in.
I'm also considering epoxy.
Sent from my tractor seat.
Re: Roll on bed liner for flooring?
Posted:
Thu May 19, 2016 9:47 am
by hankaye
funengineer, Howdy;
Don't know about the bedliner stuff, but several folks have used the garage floor paint with the
speckles in it with good results.
https://www.rustoleum.com/product-catal ... or-coatingWhen I get to that point it's what I plan on using as well.
hank
Posted:
Thu May 19, 2016 10:43 am
by Mark519
I used Rustoleum Deck Restore 10X. It is high build and very grippy. I picked the Russet color which does show dirt and tire marks especially on spots where tires are strapped down. I am going to use my old coin mat over it to protect it. The bed liner products only come in black I believe. I think using bed liner/deck restore on the ramp and 2-part epoxy paint on the body would be a good choice.
Posted:
Tue May 24, 2016 6:39 am
by funengineer
Thanks for the suggestions guys.
I have decided to install a roll on bed liner product from Monstaliner. It can be purchased in 30+ colors but I have decided to go with the black. I'm hoping that the texture will help to hold my tires in place when they are strapped down and that the black won't show any tire marks should they move around some. If this is successful I'll use red Monstaliner on a Wheel Horse garden trailer I need to restore.
I decided against the epoxy because I was afraid it would crack on the plywood seams and then delaminate along those cracks due to the flexing of the trailer. I have epoxy on my garage floor and love it but its heated and doesn't flex like my trailer does. The Monstaliner should hold up to flexing and expansion and contraction during the winter. I will use a roll up area rug in the trailer when camping. I plan to post some pictures of the process once I'm done.
Thanks again for your comments.
Posted:
Tue May 24, 2016 11:49 am
by AnthonyH
Posted:
Tue May 24, 2016 3:35 pm
by funengineer
This is what I first considered AnthonyH. It was 8 foot wide and $12 a running foot. I've since learned that if you glue it down it will bubble up and wrinkle. Those I've talked to that have used it successfully did not glue it down which allowed for expansion and contraction=no wrinkles or bubbles. I decided to go a different direction because I was concerned that my cargo shifting may move the rubber flooring. I do like the product however.
Posted:
Wed May 25, 2016 2:27 pm
by McDave
I went with the diamond flooring. Haven't installed yet, but I'm thinking adhesive or double sticky carpet tape in the center strip where bike sits, and floating at edges. Probably have to glue it and screw it to the ramp. One roll will do me. Price is right, check it out.
http://www.homedepot.com/p/HDX-7-5-ft-x ... /205442047McDave
Posted:
Wed May 25, 2016 5:10 pm
by lrrowe
I am going with Allure vinyl strips. Will post photos when done....hopefully next week.
Posted:
Wed May 25, 2016 5:22 pm
by funengineer
Nice product McDave let us know how it works out for you and include pictures.
Posted:
Thu May 26, 2016 6:28 am
by funengineer
Irrowe
Is that a peel and stick vinyl?
Had a friend that used peel and stick strips and removed it after one year as it would buckle as the wood expands and contracts. It looked great when first installed. Just an FYI.
Dave
Posted:
Thu May 26, 2016 7:52 am
by flboy
That is very similar to what I bought for the "garage " area of the CTC Toy Hauler I am building. I am thinking about putting it on the ramp door also which becomes my back wall. Still pondering that one.. I bought mine from Home Depot online and the patern is like the diamond plate..
http://www.homedepot.com/p/HDX-7-5-ft-x-14-ft-Diamond-Black-Universal-Flooring-HX45DT714MB/205442047 I will be installing next week. I decided to go with a wood laminate in the area forward of the garage. So 8 ft rubber and 10ft plus vnose with laminate.
Posted:
Fri May 27, 2016 4:19 pm
by funengineer
Day one.
Remove base trim and tie-downs, clean with acetone, sand and seal with polyurethane.
Tomorrow, first coat of Monstaliner.
Posted:
Fri May 27, 2016 4:27 pm
by McDave
Cool! Let's see a link for that Monstaliner.
Mcdave
Posted:
Fri May 27, 2016 5:32 pm
by funengineer
Posted:
Fri May 27, 2016 5:40 pm
by McDave
Ooooh, that looks good! Can't wait to see it.
McDave
