tandempair wrote:Thanks for the reply. So it is the trim that makes the issue, not the windw itself. How do you seal the window against the elements? Also looking for suggestions for the dor issue. A cargo trailer place tol us the door was too thin to hold an RV door latch.
flboy wrote:How thick are the walls?.My guess is they are an inch thick which should be no problem for mounting. The issue becomes the interior trim ring which you can do without. Look.for used RV windows on Ebay. The will work fine. I got an Emergency exit window for about $30 without the trim ring.
Sent from my SM-N900P using Tapatalk
