Noticed something and wish to ask a question ...
Postby hankaye » Wed Aug 10, 2016 7:40 pm
Howdy All;
This may not apply to everyone but, ... I'll ask anyway.
Quite a few are going all out with their plumbing and I have yet to see anyone mention or
show their "Low Point Drains". As a Fulltime RVer I don't need nor use the ones that came
installed with my RV. Some folks live where they'll never need them, others, ... well what
do you do to get all the water out when it gets cold enough freeze the system? Haven't
seen it mentioned so thought I'd ask.
hank
hankaye
Re: Noticed something and wish to ask a question ...
Postby m.colley » Wed Aug 10, 2016 7:48 pm
hiya hank,
I haven't quite finished my plumbing yet but I'm installing a drain on my build. It'll be on the low side of my water tank, complete with shutoff. I'll be able to use a small air charge to clear any water out of the tank and associated lines. Its not much, just a simple gate valve that runs outside.
Martin
m.colley
Images: 83
Postby MtnDon » Wed Aug 10, 2016 7:49 pm
We blow air through the lines to ensure they are drained. That has worked for a long time for us, both in RV and cabin use.
MtnDon
Images: 24
Postby lrrowe » Wed Aug 10, 2016 8:06 pm
I use an air compressor and RV antifreeze.
Bob
lrrowe
Images: 439
Postby Padilen » Thu Aug 11, 2016 6:58 am
I installed a flex line with shut off into my plumbing. I can then stick the line in a gallon of anti freeze and turn on pump. Pump anti freeze into water lines but not my holding tank. I did find that my holding tanks pre installed drain doesn't drain it !
Padilen
Postby flboy » Thu Aug 11, 2016 1:00 pm
I have a low point drain on the tanks... however, my ultimate solution is to avoid temperatures below freezing. :-)
Sent from my SM-N900P using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Mike S » Sun Aug 14, 2016 9:51 am
Yep, I have a low point drain for the hot and cold water lines. My system is all PEX with brass fittings, so I use brass ball valves for the drains. And the hot water heater drain is another low point. Actually we used our trailer all winter over the last two years. I've kept the system above freezing so haven't had to drain anything except the six gallon water heater. So I've never used the low point drains, LOL.
2013 7 x 16 Charmac Stealth CT , deep in conversion process :)
http://www.tnttt.com/viewtopic.php?f=42&t=66412
2011 Toyota Tundra, 4x4, Double Cab, 5.7L
Mike S
Images: 54
Postby nunrleft » Thu Aug 18, 2016 3:52 pm
Low point drains documented on page 4 of my build, with pictures. http://tnttt.com/viewtopic.php?f=42&t=62689&start=45
nunrleft
