Iconfabul8 wrote:You might consider a Torflex axle and forgo the shocks. They ride better than springs. I did the 45 deg down start Torflex axle w/brakes.
jwh92020 wrote:I just ordered a 7 x 14 single axle VNose for my conversion. It has a 3500 lb axle w/brakes. Based on a previous build, the interior should weigh in at 1500 lbs, which should leave me undercmax load weight. I won't have holding tanks (unless you count the porta potty tank) as it will always be used with hook ups.
