Originally the trailer started out as a nothing fancy 2016 7x16 Carry-On Cargo Trailer. Originally I purchased it to move from Washington to California. Once I had it I decided the heck with it and tore into it.
So I started out and gutted the original paneling in the trailer. I did 1" rigid foam insulation throughout.
I got a good deal on some laminate flooring and installed that as well.
Then I moved on to install the wall paneling. I ran wires for a 110 outlet on one side and installed the roof paneling and LED lighting. Also I got the fantastic vent installed.
I ended up getting the cabinet configuration I wanted and went to work on that. Three drawers on the left side then a large cabinet at the front with two smaller cabinets to the right. The cabinet farthest right will end up being for my electrical power panel and associated equipment.
Underneath I got two 20 gallon water tanks and plumbed them together. I then made brackets to tuck them between the axles and between the frame rails. I installed a standard rv fill port along with a city water connection. I went inside and installed a shurflo water pump beneath the drawers. I plumbed all interior lines with PEX and installed the sink, faucet, and shower.
Now this is where I am starting to rack my brain. I want to build a shower that is portable and can be used indoors and something that is aesthetically pleasing both erected and stored away. Any ideas would be great.
So after the plumbing was knocked out I started to work the electrical. I got the power converter mounted up, the 30 amp outlet installed and ran the 120 to two outlets temporarily. I hooked up all the 12v systems and installed a LED light strip on the side of the trailer.
I then installed the cargo-buckle tie downs in the trailer. I am a big fan of these, flush mount design, integrated ratchets strap and good and strong.
So a little more backstory as to why I am going with a toy hauler design over a standard trailer with living quarters and a dedicated bathroom is so I can haul this guy out for desert trips.
So after I got all of the above installed it was time to take the trailer out for its maiden voyage and test out the systems and make notes for improvements. One thing I found is the floor gets good and cold, I have decided to install 2 inch rigid foam insulation under the trailer. Another issue is heating in general. I have a Mr. Buddy Portable Buddy heater but to be honest I have never felt comfortable running it. I felt like I should have brought a bird along that way I know when I need to get out of there! (I installed a carbon monoxide/ propane detector prior to the trip though). I think I want to go with this ducted heating system right here:
http://www.rockymountainwesty.com/Prope ... hs2211.htm
Should be sufficient for the size of the trailer and it has a low amp draw on the batteries.
One thing I forgot to mention was the water heater setup. I went with the ecotemp tankless water heater. I sourced quick disconnects for brewing beer and mounted the female end in the lower front end of the trailer. I hooked the male ends to the water heater. This allows me to easily connect the water heater during setup and just as easily disconnect and drain during teardown. I also made a jumper hose while trailering just in case the water pump switch gets turned on I'm not spewing water down the road and empty when we get to the campsite.
In the last few days I have been getting back into the flow of things. Built shelving for the helmets. I decided to do LED lighting in the shelves as well to give it a little bit nicer look. I also installed two more outlets and got them all wired up to the power converter. I got the HDMI/Coax ports installed to. The HDMI runs from the upper shelf to behind the TV. And the coax will run out and through a port in the exterior of the trailer just in case I ever want to do satellite.
Yesterday I got the sliding shelves installed adjacent to the power cabinet. This was a total fluke that they fit so well, it was never my intention but I saw them and did a little modification to fit the depth, but the width is spot on.
So far that where I am at. Still have quite a bit of work to do until it's complete. I have OCD so taking my time and doing it right is key at all points. Please provide feedback or any constructive criticism you may have.
