Page 1 of 1
window placement
Posted:
Thu Feb 16, 2017 2:06 am
by yycwrangler
My 6x12 Neo trailer will have 3 - 30x30 sliding windows. 2 on the drivers side and 1 on the passenger side.
My question is thoughts on best position for them. My thoughts were to be able to look out them when sitting in a dinner type unit at the rear of the trailer. So not too high. But then if they are too low when you stand up you might have to bend down to look out them.
Thoughts??
How about positioning. My thoughts were 1 foot in from the rear of the trailer and the driver front 1 foot in from the front of the trailer.
Anyone do anything different
Cheers
Al
Re: window placement
Posted:
Thu Feb 16, 2017 8:00 am
by Padilen
I have only installed on small window in my door so far. But staggering windows as oppose to directly across from each other. Is what the experts suggest. My friends ordered their new trailer with 2 windows and they are across from each other
. The door "window" is just frosted glass.
Posted:
Thu Feb 16, 2017 9:52 am
by flboy
It is a matter of personal preferences and whether you care about seeing out more easily standing or sitting (I chose sitting since I'd be doing more of that inside the CTC); however, you'd be able to get good cross side ventilation in a breeze if at least two of the windows were across from each other.
Posted:
Thu Feb 16, 2017 10:38 am
by onehoser
since my 5x8 tin-tent is only 5' tall i placed my windows high so i can see out while sitting and closer to the rear so that:
1) i don't have to climb onto the bed to open/close the windows
2) to prevent the bed from getting wet in a sudden downpour
3) if either half of the bed is in the up position it doesnt block the window
olllllo
Posted:
Thu Feb 16, 2017 11:32 am
by McDave
ZERO windows...5 peepholes strategically placed, LED strip lighting, fan, AC, motion detector porch light and interior "warning light". I'm not paranoid....much
McDave
Posted:
Thu Feb 16, 2017 11:53 am
by funengineer
I have a two Tone trailer. Black on the back silver on the front with a chrome slash. Here's a picture from my phone album. I installed my 15 x 30 windows in the black section and put them so that I could see out when I was standing up inside the trailer but hopefully nobody could see in.
Posted:
Thu Feb 16, 2017 12:02 pm
by beachguy005
Padilen wrote:I have only installed on small window in my door so far. But staggering windows as oppose to directly across from each other. Is what the experts suggest. My friends ordered their new trailer with 2 windows and they are across from each other
Padilen, What's the spare tire bracket on the trailer? I'm looking outside mounting options for mine.
Thanks,
Posted:
Thu Feb 16, 2017 12:47 pm
by CoventryKid
I go with Don's (flboy) comments. It's personal preference as well as what the interior layout of your trailer is/will be.
The two large windows at the rear of our trailer are low - "sitting height" so we can see outside while sitting. Yes you have to crouch a little to see out when standing.
The small kitchen window was a no-brainer - high enough to clear the sink, but low enough to be under the upper kitchen cabinets.
Do you have a plan for the interior of your trailer? Perhaps you can post it?
Hope this helps.
Posted:
Thu Feb 16, 2017 6:02 pm
by Padilen
beachguy005 wrote:Padilen wrote:I have only installed on small window in my door so far. But staggering windows as oppose to directly across from each other. Is what the experts suggest. My friends ordered their new trailer with 2 windows and they are across from each other
Thanks,
I don't know it's my friends new trailer. I built their platform / loft bed. I can't remember if it's a NEO or R&R. But it's an option from the manufacturer.
Posted:
Thu Feb 16, 2017 6:52 pm
by yycwrangler
Thanks guys
I've decided to go with the windows as far to the rear and at sitting height. So one on the rear drivers and one on the passenger side at the same position. I've also put a second window on the drivers side as far forward as possible. All 30x30
Coverntrykid..My plan is to emulate the boler we had previously. So sitting area at the rear of the trailer which will form a 5 foot wide bed across the rear. rear is 69" wide and myself and the wife are max 58" tall so works well. In the front I'm going to have another couch across the width of the front and it will also slide out to a bed about 30" in width. In the middle of the trailer on the driver side will be a small galley area, countertop with some shelving underneath. I also plan on cutting a couple of holes into the floor and having my portable air conditioner sitting under the countertop connected to these holes. On the drivers side about where the wheel is I will have a larger cabinet with a door. Up in the vnose (behind the couch) will be where I will keep my spare tire and incidentals like folding chairs etc. I plan to paint and run wire shelving along both sides of the trailer high up for higher stuff like sleeping bags etc.
my biggest thoughts right now are where to place the battery and electrical panel. it will be sealed so not so worried about ventilation. I'd ultimately like to use two 6v golf cart batteries but they get pretty heavy and I'm not sure if the Jeep Wrangler has the tongue weight ability for two batteries up front. My next consideration was on passenger side above wheel in the cabinet which would distribute the weight better but now I have to run electrical all the way to that location from the tongue. perhaps underneath from the tongue and up into the cabinet.
Anyhow want to be able to balance weight as best as possible
Thoughts?
Al
Posted:
Thu Aug 25, 2022 11:27 am
by primaveraduration
I think the Window is placed very well. The main problem with such big Windows is that it gets a lot of light enters the truck's interior. While I was traveling, the passengers always complained that the sunlight was disturbing them, so we had to find different methods to block it. We decided to buy some shades from
https://snapshades.com.au/. It was easy to install them, and I like that they are extremely efficient. It completely blocks the sunlight and can create a shady atmosphere even on the sunniest day.
Posted:
Mon Aug 29, 2022 12:32 pm
by Karebru
CoventryKid wrote:I go with Don's (flboy) comments. It's personal preference as well as what the interior layout of your trailer is/will be.
Yep.
The front of my trailer is basically kitchen. So those two windows are just above counter height. The wall stud spacing determined their lateral locations, and then the upper cabinet design.
Later, I added two more smaller windows up high at the very back, just to let some light in. After a few trips, we decided it needed them.
