gbowman, Howdy;
Been fulltimeing in a RV for the past almost 8 years now, if you plan on moving you trailer
you don't want to have to find a space to store the lid and drain the flush tank each and
every time you get ready to relocate. Also, you then have to fill the tank and place the lid
on for those times when you are parked and ready to stay put for awhile.
If you don't want to have to install a 'black tank' under the trailer then think about one of
these.
https://www.rvpartscenter.com/4-wheeler ... allon.htmlNow, I am NOT advocating you purchase this model, bit to spendy for me... this is only an
example as I advocate for the folks in Missouri in that I believe that by showing you an example
you'll better understand what it is that I'm attempting to explain in words.
Check your local Craig's List for parts. Keep the commode as close to the external wall so your pipe
run is as short as possible. Be sure to include a blade valve to keep the pipe end secure and
leak proof.
http://www.valterra.com/product/bladex- ... at_id=1444Valterra I
will recommend as a satisfied customer and their stuff is pretty much industry standard.
Follow that link back a page or 2 and you'll see most of what you'll need to do the complete install.
The 3" black pipe you can get at a local hardware store (box color of choice).
There's my thoughts for your question.
hank
