Aftermarket door locks
Postby beachguy005 » Mon Apr 24, 2017 12:19 pm
Hi folks, I'm curious about the locks people are installing on their doors not factory supplied. All the ones I've seen online seem to be for 1.25" doors or thicker. Mine is 1". I've been looking for the typical TT keyed latch with deadbolt.
Thanks,
beachguy005
Re: Aftermarket door locks
Postby aggie79 » Mon Apr 24, 2017 4:19 pm
You could use the standard lockset and add a 1/4" spacer to the inside.
Postby onehoser » Mon Apr 24, 2017 5:40 pm
aggie79 wrote:You could use the standard lockset and add a 1/4" spacer to the inside.
^this is what i have to do to install my rv door latch
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby beachguy005 » Mon Apr 24, 2017 5:48 pm
Thanks for the comments. I saw the spacer mentioned but I wasn't sure how well a 1.25" lock would fit in a 1" door even with the spacer. My primary concern is the fit and alignment as I'll have to drill out the frame to receive the latch.
beachguy005
