McDave wrote:Paint that roof with Henry 587, 1st order of business. Get it done. Dollar for dollar the best upgrade so far. About $50.00, and a half a day of prep/paint. Makes a huge difference.
Then use the same PolyIso you used everywhere else, fir out and double up if you wish.
McDave
QueticoBill wrote:Seems difficult to get polyios to bond to the skins like XPS or even EPS does to take structural advantage of the stressed skin construction. Can you get polyiso without a facing? I just have found the facing - usually foil - to peel very easily, which suggests to me they would fail from the shear between skin and foam.
McDave wrote:QueticoBill wrote:Seems difficult to get polyios to bond to the skins like XPS or even EPS does to take structural advantage of the stressed skin construction. Can you get polyiso without a facing? I just have found the facing - usually foil - to peel very easily, which suggests to me they would fail from the shear between skin and foam.
The best way to install the foil faced PolyIso is leave a 1/4" air gap between the inside of the trailer skin and outward face of insulation. That should reduce the thermal transfer and increase overall R-value.
McDave
QueticoBill wrote:McDave wrote:QueticoBill wrote:Seems difficult to get polyios to bond to the skins like XPS or even EPS does to take structural advantage of the stressed skin construction. Can you get polyiso without a facing? I just have found the facing - usually foil - to peel very easily, which suggests to me they would fail from the shear between skin and foam.
McDave
But do you agree that would make it of no structural value? That seems the great feature of ply-foam-ply, that they act together and can span without other support.
featherliteCT1 wrote:McDave wrote:Paint that roof with Henry 587, 1st order of business. Get it done. Dollar for dollar the best upgrade so far. About $50.00, and a half a day of prep/paint. Makes a huge difference.
McDave
In any case, I think painting the roof as you suggest is a must. However, I am still wanting to know if the roof skin will exceed 165 degrees F. I suspect it will.
I am also guessing that the paint will only reduce the temperature of the exterior roof skin about 20 degrees in the hottest scenario.
