John61CT wrote:Yes it would be nuts to run A/C without lots of as good insulation as possible, floor especially.
Lots of ventilation as well, high-volume intakes at the bottom, exhaust(s) up top, with high CFM fans and variable speed controls.
Cold weather needs more insulation up top, and precision control on the venting.
Air conditioning (often referred to as AC, A.C., or A/C) is the process of removing heat from a confined space, thus cooling the air, and removing humidity.
Just a side note for others' benefit reading laterfeatherliteCT1 wrote: asking about hot weather conditions, rather than cold weather conditions.
working on it wrote:I run A/C in my trailer, without any insulation, and the only condensation is on the outside.
I presume that, in cold weather, when the condensation formed on the inside of your trailer, it was because you were inside generating heat with your bodies and moisture with your breathe. In which case, when the warm, moist, interior air came into contact with the cool skin, the water condensated onto the inside of the skin. Just like what happens on the interior side of a glass window in a house in the wintertime.
I was mainly responding to featherliteCT1 about the benefits of having A/C and heat both available in an uninsulated space, and that airflow is also a necessary component in the equation. And to tony.latham, who brought up dew and condensation, where A/C, heaters, and airflow each contribute to solving problems in an uninsulated trailer. But, I referenced John61CT, because I took exception to your statement "it would be nuts to run A/C without lots of as good insulation as possible". It was a conscious choice on my part, since I thought that in the climate I camp in, insulation could be dispensed with, as an unneccessary complication to a plywood-only structure. In my post, I've shown methods proven to work (for me) to bypass insulation problems, and nuts as I may be for not insulating, I felt that it was the best choice, for me, at the time. My input might broaden the scope of featherliteCT1's investigation, so I added my experiences to the thread. Thanks for your input on this matter.featherliteCT1 wrote:tony.latham wrote:I'm a teardrop guy, not a cargo guy, so keep that in mind.
My first teardrop was commercially built and wasn't insulated. When the weather was chilly, dew would form on the inside of the trailer. I built our current 'drop and insulated it. It doesn't sweat. When it's 80-85ºF and we want to take a break, our ceiling fan sucks the breeze in across our bodies, out the roof, and keeps us nice and cool.
I think insulation is a big deal.![]()
Thanks for sharing,
So yes, I would absolutely, without question, want insulation in a cold climate because I would not need 120 volts to heat the inside. A propane heater would do the inside heating job.
