7x7x16 V Nose Cargo Trailer Conversion, First Build
Hi All,
I started receiving parts for my first trailer conversion, so I figured I would start my build journal (Super excited!!). I will live in the trailer full-time while doing a combination of rv parks, national forests, and boondocking. I'll be traveling with 1 dog and two cats (And with a 16 year old who no longer is interested in hanging out with Dad).
Here is the details in what I am going to attempt to build:
Trailer: 7x7x16 V Nose Enclosed trailer. Rear ramp and Side door. Dual Axle, electric brakes. Bought from Trailer Country off ebay (I know, it will probably be cheaply built, but the price was right and I liked the size. I also figure I have to harden it anyways.) Will pick up in GA on 6/2.
What I want Inside:
- AC (30 Amps)/DC for electricity (Bought and have PD4045KV).
- 300 Watt Solar System. (Bought and have, Renogy kit. Need batteries)
- Flushable bathroom, shower, and kitchen with sink. Only need propane dual burners. (Bought Shurflo 4008, Shurflo accumulator 182-200, Shurflo filter 255-213, and Ecotemp FVI-12-LP High Capacity propane tankles water heater For shower)
- I like light, so I will add two windows on the side, one window on a built wall at the back of the trailer and one skylight
- Trying to go for an open concept. I know, with such small space it's hard, but I will try.
- TV and multiple monitors. I telecommute, so this is required.
- Fridge/Freezer for food
- Will insulate the whole trailer including the floors
- Propane system. Still need to research this.
- Need to research an antenna so I can pick up good wifi from different locations.
- Will attempt to make the back door a 'patio' and screen it in so the cats can go out there. Not quite sure how to accomplish this yet.
Also, still will do research, but would love any recommendations on the following:
- 6v batteries, any brand better than others? Going 6v because I read on the forums you basically get more bang for your buck.
- Window AC Unit? Any one have a preferred one I can research? Ideally energy efficient and works well to keep me cool.
- Fresh/Gray/Black tanks. I've been looking on ebay and they seem cheap. Any recommendations on tanks or suppliers? I have no size in mind, just probably want 20 gallons or greater.
- Any reccomendations on where to find good windows? I know the window for the back will be easy cause I can use a regular house window. Not to sure about the windows for the side of the rv.
- Flushable toilets? Any good ones to look for? I plan on using a black tank and placing it right under the toilet. I like the idea of cassette toilets with removable tanks, but they sure are pricey.
- Also, I don't see this talked about much on the forums. But how will I know that once the water leaves my shower or sink that it will actually make it to the gray tanks? What if it doesn't just 'flow' there? Do people use extra pumps for this? Or just design it a certain way?
I look forward to journaling my build and learning and asking many questions as I go through this process. I know there is so much I don't know yet, and really hope the vets can guide me when I need it.
Below first rough designs are below. Any feedback or anything that looks off please let me know! I didn't really consider weight distribution too much. But I put the water tanks on both axles and tried to spread stuff out.
What I want Inside:
