tony.latham wrote:I think it'd be fine as long as you put a moisture barrier between it and the living space. (Between your luan and the fiberglass.) Otherwise it may attract condensation.
tony.latham wrote:Condensation happens when warm, moist air is cooled by a cold surface. If you have an impermeable barrier at your ceiling, below the insulation––where it will be warm––the moisture will never find a cold surface to condense on. It can't get there. If there is not barrier, it will travel through the fiberglass and find the cold aluminum and condense.
Now... that's just my opinion.![]()
T
tony.latham wrote:Bill:
"- there's no way for the cavity to ever dry out." Just out of curiosity, with your hypothesis, how would the moisture ever get in the insulation since it's sealed above and below?
Just a friendly question.
T
McDave wrote:My biggest concern would be the potential for airborne glass fibres all the time. Unless those batts are hermetically sealed, then the potential exists for the fibres to shake out during transit and cover the interior and embed in clothes, blankets, carpet etc. If they ever settled, the next transit would re contaminate. You would need to have a barrier to seal the glass in under the luan. I don't know that would happen, but I'm pretty sure you don't want to suck that in while eating and sleeping.
McDave
