McDave wrote:That is definitely a up scale trailer. In it's day I'm sure would be up there with the Neo's and Featherlights etc.
It looks like the wall studs are 4'? One piece roof should be an advantage and the overall condition looks excellent, 4 new tires and one owner, I'm not really sure that is overpriced. In my market any cargo trailer is hard to find used and they sell fast. If you consider that it's one owner and hasn't been horse whipped, seems like a good value. If your alternative was a new trailer, well that first trip home is very costly due to the instant depreciation. That won't be an issue here. I guess it's like most things, It's worth what you can get for it. I would have to grab it before somebody else did. It will probably be a long time before a nicer used trailer comes along.
I don't think it would be impossible to fab a ramp door, and find the spring/cable assem. or possibly an entire ramp and spring, although the odds of finding an exact match are slim. May find one close enough to modify. And in the mean time use a portable ramp. It may turn out that the barn doors are a boon based on some of the designs we've seen. Dirt bikes are not as tough to load as 900 lb Harley's etc.
I like it. A lot.
McDave
Thanks McDave. Good call on the stud spacing but hard to believe though. And difficult to know if it was horse whipped as he did mention he lent it to friends.. But the clearance between the tires and fender wells look sufficient and
may indicate the torsion axles haven't been over loaded.
I'm so busy with other projects I'm not worried if it's sold out from under me, but I better make a offer before someone else does. I think its overpriced after searching ebays
sold listings and I rarely buy new.
https://www.ebay.com/sch/Cargo-Utility- ... 5573.m1684As far as the ramp door.. I think I could jack up the front or use a hill to load my DRZ400s. Or just have a single ramp. Definitely not a perk though and worth less to me. What I really like about the trailer is that the wheels are under the trailer, and total width very close to the tow vehicle as I plan on towing this up fire roads in Colorado. But double torsion axle aren't the best choice for pot holes and dirt roads.
John61CT wrote:Torsion axles don't get repaired but wholly replaced.
And nothing lasts forever.
Any way to inspect/test them? Maybe see who made them, give a call?
Very good point John. I did a little research on how to know, and the only way I came up with is eye balling the clearance between the tires and fender wells..
Thanks for that. That trailer is $4,550.00. Yes its smaller but
brand new. There's no way I'm paying his $4200 for a 17 year old trailer and I think a offer of $3000 is more than fair.
