I screwed a metal AC receptacle box to my trailer framework. This will ground the trailer frame. Is this a problem in anyway?
Re: Another Grounding Question!
Posted: Fri Oct 06, 2017 5:54 am
by McDave
So the frame would be grounded when connected to shore power? That sounds correct. In fact I believe your PD4045's and WFCO's also require a ground bond to frame.
