Cargo trailer plumbing
Postby buelrdr29 » Mon Nov 27, 2017 1:02 pm
Who has some experience with mounting the tanks for a cargo conversion? Any suggestions on methods and locations. I am planning the fresh water to be built under the counter and need to figure out the black tank placement. I will be doing a shower and toilet. Also, is a grey tank necessary or does anybody just use a larger black tank? I bought a camper for parts and appliances and hope to reuse the tanks and such.
I am using a 7x16 v-nose double axle. I am a bit worried about how low the tank drain will be. The trailer is for camping and hauling my dirt bikes, so offroad sites are common use.
buelrdr29
Re: Cargo trailer plumbing
Postby McDave » Mon Nov 27, 2017 2:46 pm
I have a similar set up to what you are describing. I carry 25gal fresh and 29gal black tank, no grey. I also have a diverter valve at shower drain to divert shower water to ground when acceptable. I mounted fresh tank underneath just behind axle. I needed the weight behind axle to help balance out tongue weight. It seems pretty safe as axle is lower than tank. Been a couple years now, no issues.
This is the black tank I used, the valve just clears the frame. Also no issues so far.
https://www.amazon.com/gp/product/B004R ... UTF8&psc=1
The "Hepvo" trap works great and saves a lot of room over a P trap. You wont need to raise floor for shower plumbing and don't have to worry about trap drying out.
I chose to have a "wet bath" style like you would find in a truck camper or small RV, the shower and toilet are in the same pan, 3" drain for toilet, 1.25" for shower. Saves a lot of room, about 3 ft x 3 ft.
When you get to laying out your floorplan keep in mind weight and balance and tongue weight. This calculator will help.
https://www.engineersedge.com/calculato ... alance.htm
Remember water is about 8 lbs/gal. I tried to set up so Harley was balance neutral so trailer was still balanced when not hauling bike.
Good Luck!
McDave
McDave
Images: 412
Postby Iconfabul8 » Mon Nov 27, 2017 6:05 pm
My plumbing stuff starts on the bottom of page 7 thu 8 and 9. It might give you some mounting ideas.
http://tnttt.com/viewtopic.php?f=42&t=66362&start=90
Iconfabul8
Images: 14
Postby McDave » Mon Nov 27, 2017 8:55 pm
Several people have done a axle flip for lifting trailer about 3"-5". May help for offroad travel.
McDave
McDave
Images: 412
Postby MtnDon » Mon Nov 27, 2017 9:35 pm
One reason RV's are built with grey and black tanks is when dumping the grey is dumped after the black and helps to wash the black stuff out of the hoses, etc.
MtnDon
Images: 24
