Window Sourcing
Window Sourcing
Postby Mr. King » Tue Dec 12, 2017 2:47 pm
Greetings All,
Where do you get your windows?!
I am in the process of converting a cargo trailer that I had custom built about a year ago.
There are three windows installed in the trailer, one of which will not accommodate the 2" thick walls. Yes, it is insulated to the point that about the only conduction paths are the window frames themselves and the door (1½ inches of foam).
Anyway, back to the original question... I'm looking for a window to fit a 30¼" x 30¼" x 2" opening. HELP!
Thanks!
Mr. King
Mr. King
Re: Window Sourcing
Postby onehoser » Wed Dec 13, 2017 9:03 pm
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Re: Window Sourcing
Postby McDave » Wed Dec 20, 2017 4:20 pm
Do you need the complete window or would a proper sized ring do the job?
McDave
McDave
Images: 412
Re: Window Sourcing
Postby jjvw » Sun Dec 31, 2017 8:13 pm
Don't know where you are, but if your near the MI/Indiana border, look up Bontrager's surplus, white pigeon, mi. $40 ea they will ship.
jjvw
Images: 23
Happy New Year
Postby Iconfabul8 » Mon Jan 01, 2018 3:20 am
I have seen a few people just screw the window on from the outside. Make sure you have something to screw into and might work in your case.
Iconfabul8
Images: 14
Re: Window Sourcing
Postby daveesl77 » Mon Jan 01, 2018 8:04 am
Check out larger auto salvage yards. They will often have RVs of all types. You can get some very, very good deals. Windows, water pumps, electric distribution, wiring, water tanks, oh and in one case I paid $10 for anything I wanted inside one RV and found $78, a window AC, 38 gal fresh water tank, new pump and a decent 3 way fridge.
dave
daveesl77
Images: 273
Re: Window Sourcing
Postby McDave » Sat Jan 06, 2018 12:07 am
Here is a drawing of window installation when window is thicker or thinner than wall.
152489
This is the source.
http://www.busrvparts.com/bus-rv_windows.htm
McDave
McDave
Images: 412
Re: Window Sourcing
Postby Mark959 » Tue Jan 09, 2018 8:55 pm
McDave wrote:Here is a drawing of window installation when window is thicker or thinner than wall.
This is the source.
McDave
Some rings can be flipped too. I'm not sure where you can order different depth rings...
Mark959
Re: Window Sourcing
Postby RAYVILLIAN » Wed Jan 10, 2018 12:27 pm
If your any where near south Missouri Colaw rv salvage in Joplin has a lot or them.
Gary
111961Image
RAYVILLIAN
Images: 109
