Sad Accident - Propane heaters
Postby Rainier70 » Mon Jan 01, 2018 3:33 pm
3 family members found dead at Brown County deer camp
http://www.ktxs.com/679434246
Please be very very careful with propane heaters and ventilation.
Rainier70
Images: 244
Re: Sad Accident - Propane heaters
Postby flboy » Mon Jan 01, 2018 4:22 pm
Rainier70 wrote:3 family members found dead at Brown County deer camp
That is so tragic. I feel so bad for the families involved.
I don't trust the propane heaters and will not go to bed with them on. Even with a CO2 detector and so called "proper ventilation". . I will heat up the CTC just prior to going to bed and then when I wake up. If I found myself in a situation where I needed heat all night, I would probably use my 1500W Ceramic heater and just run the generator. If it was a regular need (and is not in Florida) I would install an
propane furnace where the flame and etc. is all vented outside. I actually have one from the donor camper I never installed,
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby mckenzieclan » Mon Jan 01, 2018 8:42 pm
Tragic,...please be safe out there, vent propane externally, and please use CO, O2 & Explosive gas detectors.
Jonathan
mckenzieclan
Postby crttaz » Tue Jan 02, 2018 5:02 am
You will wake up when too cold.
Warm up the place you are sleeping, shut off the propane before going to sleeping, or have a timer circuit. Wake up in the night cold? Run propane for 30 minutes and back to sleep.
Might not be known here, but water vapor is a by product of propane combustion. I deal with it on cold tools in the garage all the time.
crttaz
