Rv toilet and portable sewage tank question.
Postby mlowry7 » Fri Mar 30, 2018 10:39 pm
Would it be feasible to install a traditional RV toilet plumbed to dump directly into a portable sewage tank on wheels. In other words, there would be no permanent black tank. I’m assuming my issue with this idea would be venting. Any thoughts? I’m trying to get away from a vent stack going through the roof.
mlowry7
Re: Rv toilet and portable sewage tank question.
Postby FlyBye » Fri Mar 30, 2018 11:19 pm
That's my understanding of what "Honey Wagons" are for. That is your temporary "holding tank" and you roll it or pull it behind your vehicle/rig to the designated disposal spot when at a camp ground. The permanent "Black Holding Tanks" are nice when you are traveling from spot to spot and it's either not convenient to or the proper dumping stations are not available.
FlyBye's 7x16 Cargo Camper Build
http://tnttt.com/viewtopic.php?f=42&t=69287
FlyBye
Postby Iconfabul8 » Sat Mar 31, 2018 2:29 am
Check out Haders venting solution, it is pretty slick. http://tnttt.com/viewtopic.php?f=42&t=6 ... 5#p1207849
Iconfabul8
Images: 14
Postby Augie Dog » Sat Apr 07, 2018 4:25 pm
I am going to use an RV toilet and set up you are going to use. I feel the simpler the better!
Augie Dog
