Page 1 of 1
Factory installed wall vents?
Posted:
Fri May 11, 2018 3:42 pm
by Karebru
You know... The "In" vent, high on the drivers side, and the "Out" low on the passenger side.
What does everybody do with them?
Instinct tells me that completely air tight is not good. Even with air conditioning.
I guess one could put an operable cover over them on the inside if they wanted to be able to close them off.
My in vent will be over my porta-potty. I'm thinking, exhaust fan.
Re: Factory installed wall vents?
Posted:
Fri May 11, 2018 4:24 pm
by Joel.brian
My trailer only came with one roof top vent that I changed into a Maxx fan.
Posted:
Fri May 11, 2018 5:33 pm
by featherliteCT1
My trailer came with a vent up high on the wall on the driver’s side in the front and another vent low in the rear on the curb side.
I never leave them open when I travel to avoid road dirt from getting inside the trailer. I was surprised about how much road dirt came in when I left them open.
Now, when stationary, I almost never open the rear vent but use the front vent quite a bit. I also have two vents on the roof plus a Maxxfan on the roof.
The first time I slept in my trailer after installing insulation, I tossed and turned all night and I woke up in the morning with a bad headache. Thereafter, somewhere on this site I read where you can suffocate in a sealed trailer ... duh. I think I was being asphyxiated. Now I leave vents open when I sleep regardless of whether it is hot or cold outside.
Posted:
Fri May 11, 2018 6:06 pm
by Iconfabul8
I plugged them. I figured with three windows and a wall vent I could get the ventilation I want. Besides one was behind the shower and neither were closeable. I think those vents are designed to remove fumes from the lawnmower and atv's and such. Probably a good idea to keep if you are hauling those.
Posted:
Fri May 11, 2018 6:28 pm
by onehoser
i just cover them with tape and then remove the tape when i need the ventilation
Posted:
Fri May 11, 2018 7:11 pm
by Karebru
featherliteCT1 wrote:I never leave them open when I travel to avoid road dirt from getting inside the trailer. I was surprised about how much road dirt came in when I left them open.
Never thought of that.
Yep. I think I saw that in the main teardrop section. The smaller the space, the quicker it could happen.
Even a large volume home isn't completely air tight. Some air moves in and out through things like recessed ceiling lighting, exhaust fans, etc.
Posted:
Fri May 11, 2018 8:04 pm
by Padilen
I use mine. Plus I added one. I use furnace filter material inserted in then to filter and keep bugs out. The one upper one is my black water tank vent( no filter) The second upper is my bathroom/shower vent with a computer fan.
Posted:
Fri May 11, 2018 10:45 pm
by MtnDon
If you can buy without them you are better off IMO. Then you can place them where you want them and not have to block off anything. As was mentioned they are horrible if you travel dusty roads.
Posted:
Sat May 12, 2018 8:03 am
by Hader
We ordered ours with no vents of any kind, but the factory installed a roof vent (i wish they didn't).
For the bathroom, we went through the floor w/ the AC vent:
http://httpswww.tnttt.com/viewtopic.php ... 5#p1208114We were planing on using these for venting.
https://www.etrailer.com/s.aspx?qry=ven ... pm-Redline
Posted:
Sat May 12, 2018 2:07 pm
by John61CT
Being ABLE to get a 100% seal is a good goal, you want control over ventilation
especially in dusty conditions, I've seen rigs where they use air filtration and constant positive pressure while driving.
That said, when you're in the space you always want some constant airflow, up to very high CFM exchange capacity when needed, not just hot weather e.g. cooking inside or otherwise burning propane, high-aerobic exercise 8-)
Posted:
Mon May 14, 2018 5:05 pm
by McDave
John61CT wrote:Being ABLE to get a 100% seal is a good goal, you want control over ventilation
If the trailer is rockin'...
McDave
