Wind Turbine for the CTC
Anybody have any experience with these 400W wind turbines? I was going to build my own from a car alternator/generator and cut blades from a 4" PVC pipe, but these seem inexpensive enough. I know there are others of better quality and I would pay more. I am just wanting to know if these type of wind turbines would be a good idea for when I go out west into the desert. My understanding is that the winds blows all night sometimes and even during the day, so this would allow a charge at night and of course I'd have solar in the day. In solar and with the winds blowing, I could run my AC while charging the batteries slightly. Thoughts? I'd mount to the antenna mount I already installed and it would have a separate controller to the battery bank.
Also,5 blades or 3? 5 Blades would probably work better in lower wind speeds for starting and etc.? I do not see great reviews for these anywhere... probably a good reason for that... a lot seem to be about the start speed (advertised at ~7mph) and the need for at least 20mph wind to get a decent output. What is the wind speed out in the desert at night? I have been out there before and it seemed to be more than just a good breeze...
I see these on sailboats around here all the time and I have seen them on a few RV's that are parked. Obviously I'd slip it off the mount for travel. Maybe should forget about it and supplement with the Honda 2000 as needed?
https://www.ebay.com/p/400w-Max-Power-3 ... 0005.m1851
