Bed lift
Bed lift
Postby Iconfabul8 » Thu Aug 09, 2018 3:17 pm
There is always a lot of interest around here in bed lifts. For some time now, I have been purporting the concept of a drawworks under the bed. My Sketch
Until now, I haven't seen it implemented. I hope ya'll find the links below helpful and enlightening.
https://www.fordtransitusaforum.com/cam ... post286521
https://www.fordtransitusaforum.com/cam ... post364530
Iconfabul8
Images: 14
Re: Bed lift
Postby cg_ops » Thu Aug 09, 2018 5:53 pm
As I'm sure my post triggered you to make this one, my last reply might be of some help to people. (Instructions directly from Lippert on how to request a quote)
viewtopic.php?f=42&t=70757&p=1234914#p1234914
cg_ops
Re: Bed lift
Postby flboy » Sun Dec 09, 2018 4:20 pm
Iconfabul8 wrote:There is always a lot of interest around here in bed lifts. For some time now, I have been purporting the concept of a drawworks under the bed. My Sketch
This is what I'd like to try if doing all over again. Looks simple and cables are hidden.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: Bed lift
Postby Bowtie76 » Sun Dec 16, 2018 8:13 pm
Funny,
I'm just starting my build. Going to start a thread soon. I have the same setup the ready to install for lifting my bed.
Will post pics and follow up on how it works when I get it done.
Bowtie76
Re: Bed lift
Postby flboy » Mon Mar 11, 2019 12:20 pm
Anyone have any idea where to source the hardware for the bed lift shown in the Transit van. I have no problem with the pulleys, but the bar that wraps the cables and that has the crankshaft is where I am stuck.
A few trips with my wife and it is apparent I need the bed at the lowest point for sleeping and then be able to crank up as needed.
Don (Flboy)
flboy
Images: 378
Re: Bed lift
Postby Padilen » Mon Mar 11, 2019 12:32 pm
flboy wrote:Anyone have any idea where to source the hardware for the bed lift shown in the Transit van. I have no problem with the pulleys, but the bar that wraps the cables and that has the crankshaft is where I am stuck.
Don,
On a Facebook post which I can no longer find. And of course I've forgotten their name. There is a 12 volt motor on a track. They used 2 , 6' 150lbs units, at center of bed. Garage door track on each corner. Looked good and slim profile.
Padilen
Re: Bed lift
Postby flboy » Mon Mar 11, 2019 12:39 pm
Thanks Padilen. I found it.
Racor - Ceiling Storage Heavy Lift - Up to 250 lbs https://www.amazon.com/dp/B0009I8AO6/re ... HCbZCCWGJP
Don (Flboy)
flboy
Images: 378
Re: Bed lift
Postby Padilen » Mon Mar 11, 2019 1:22 pm
flboy wrote:Thanks Padilen. I found it.
Nope not that. It's a motor on a track. Very neat and probably what my "designer" had in mind before he putzed out on me.
No cables no pulleys!
Padilen
Re: Bed lift
Postby Padilen » Mon Mar 11, 2019 1:24 pm
I found it.
https://www.facebook.com/groups/1523347 ... 838994672/
Padilen
Re: Bed lift
Postby aggie79 » Mon Mar 11, 2019 1:25 pm
Don,
Look forward to your bed lift project. Do you think you'll invert the garage lift with the motor, crank and pulleys under the bed?
Take care,
Re: Bed lift
Postby flboy » Mon Mar 11, 2019 1:45 pm
Padilen wrote:I found it.
Link is not working?
Don (Flboy)
flboy
Images: 378
Re: Bed lift
Postby Padilen » Mon Mar 11, 2019 1:55 pm
It does for me with tap talk.
But this it what was used.
[https://cdn]
Track Linear Actuator
Model: PA-18
Stroke2-60 inch
Force150-900 lbs
Speed0.25-1.5"/sec
His name
Craig Rose
On Facebook's
Cargo Trailer ConversationsImageImageImageImage
Padilen
Re: Bed lift
Postby flboy » Mon Mar 11, 2019 2:06 pm
Don,
Take care,
That is what I have in mind ( mount upside down with hardware under bed).
I will have to take my existing bed out and start from scratch. I may just get some 1 in square steel stock and tack it altogether and get someone who knows how to weld to make it pretty.
Will add plywood to top and trim with wood.
The $500 for the Amazon hardware seems a bit steep for what it is. I really would just like the gearbox and shaft. Since I am going this route, I may fab something similar with garage door hardware.
Will be a project. Will share as I go. Will a month or so before I start. I am helping someone else with a project before I start.
Don (Flboy)
flboy
Images: 378
Re: Bed lift
Postby flboy » Mon Mar 11, 2019 2:09 pm
Padilen... I can see that now. Wow. That is clean. I could keep the bed as is and with existing trolleys! Going to explore that so more before I start over. Thanks.
Don (Flboy)
flboy
Images: 378
Re: Bed lift
Postby Treeview » Mon Mar 11, 2019 4:11 pm
Treeview
Images: 30
