Bolting D ring and Wheel Chock on underside of trailer?
Postby Mtnadventure14 » Wed Sep 12, 2018 1:47 pm
I am designing the layout for where all of the 4 dirt bikes will go within the rear of the 7 x 20 trailer.
I plan to have D rings with chains attached to each peg and then wheel chocks for the front wheels. Perhaps a dumb question. How is everyone getting the trailer high enough to install these bolts and how are others waterproofing around these bolt installs on the underside of the trailer (if at all)?
Thanks.
Mtnadventure14
Re: Bolting D ring and Wheel Chock on underside of trailer?
Postby hankaye » Wed Sep 12, 2018 6:19 pm
Mtnadventure14, Howdy;
Drop the nose for rear clearance, perhaps. As for sealing around the bolt holes push a dollop of silicone
into the hole, follow with bolt, tighten the washer and nut, wipe off excess. Simple, .. no?
hank
hankaye
Postby flboy » Wed Sep 12, 2018 6:39 pm
Mtnadventure14 wrote:I am designing the layout for where all of the 4 dirt bikes will go within the rear of the 7 x 20 trailer.
Thanks.
It is a tight fit unless you jack it up. Before I flipped my axle to raise it up, I would have to jack it up if I wanted to work underneath. I siliconed around it, but now I have insulation covering them , so no issues,
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Padilen » Wed Sep 12, 2018 6:55 pm
I used a couple different ways to attach my wheel chock, and other things through floor.
Since I don't like silicone I avoid using it.
Galvanized bolts can be used too.
I used a wood waterproofing product in the holes I drilled. Anti seize on bolt threads. Large fender washers, lock washers and nuts. I had some nyloc nuts and used those, too. I used T nuts for my hand rail. I also installed ridged insulation underneath, caulking all seams. I then painted Drylok over it.
Padilen
Postby Mtnadventure14 » Thu Sep 13, 2018 6:43 am
Thanks for the ideas. Yes - definitely sounds simple just was curious of the methods that had been used successfully before. This forum is an excellent resource and always provides some great, detailed answers.
I have dual stabilizer jacks on the rear of the trailer as well so I may be able to utilize those because the D rings and wheel chocks will be towards the rear of the trailer.
Mtnadventure14
Postby flboy » Thu Sep 13, 2018 7:28 am
You are welcome. Be careful under there when jacked up.
Don (Flboy)
flboy
Images: 378
Postby McDave » Thu Sep 13, 2018 2:29 pm
You could drive it up onto the curb of the sidewalk on one side. It wont be level but you can get under it without jacking it up. Shadetree mechanic's trick.
McDave
McDave
Images: 412
Postby hankaye » Thu Sep 13, 2018 6:34 pm
McDave wrote:You could drive it up onto the curb of the sidewalk on one side. It wont be level but you can get under it without jacking it up. Shadetree mechanic's trick.
McDave
Building on a theme, a stack of 2x6 or 8's with the ends staggered to roll up and off of,
A set of ramps used for oil changes,
But, if you use jacks please invest in some jack-stands for safety.
hank
hankaye
Postby McDave » Thu Sep 13, 2018 8:46 pm
Or dig a trench and drive over it? ... :thinking: ...
McDave
McDave
Images: 412
Postby flboy » Fri Sep 14, 2018 6:39 am
hank
Absolutely!! Never get under the vehicle without them!
Don (Flboy)
flboy
Images: 378
Postby dirtsailor2003 » Sat Sep 15, 2018 2:39 pm
Another option, no d really MB’s or chocks on the floor. Install E track on the walls and tie down the bikes to E Track. We haul three bikes doing just that with no issues.
dirtsailor2003
Users browsing this forum: onehoser and 9 guests
