Table top in V nose?
Postby atcNick » Wed Jan 16, 2019 1:05 pm
I want to built a table top in the nose of my V nose cargo trailer. Are there any tricks to doing it so you get a good fit?
-Nick
atcNick
Re: Table top in V nose?
Postby flboy » Wed Jan 16, 2019 1:14 pm
atcNick wrote:I want to built a table top in the nose of my V nose cargo trailer. Are there any tricks to doing it so you get a good fit?
Take some cardboard and cut a template on the floor as the guide and use that to trace to the wood. I did that and it fit like a glove.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby StrongFeather » Wed Jan 16, 2019 1:15 pm
You could make a template, then transfer the outline of the template onto the finish stock material.
Edit: Looks like FL and I posted at the same time.
Build Journal viewtopic.php?f=50&t=71138
Composite Panel Construction Technique viewtopic.php?f=21&t=71192
If women don't find you handsome, they should at least find you handy.
~Red Green
StrongFeather
Images: 30
