Ramp idea for barn doors
Postby Padilen » Thu Feb 28, 2019 4:12 pm
Just saw this on ADV rider. Might be useable for those wanting to convert a barn door trailer to a toy hauler.
https://youtu.be/4qX4D9OqGIs
Padilen
Re: Ramp idea for barn doors
Postby flboy » Fri Mar 01, 2019 8:38 am
That looks expensive... probably better off just to replace Barn Doors with a Ramp door if that is what is needed. Short of replacing the door, I'd just weld some brackets underneath to hold/store some ATV ramps that can be pulled out when needed assuming the Barn Doors are preferred and ramps would just be an occasional use.
Now if I had a van like that... looks perfect.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby rebar » Sat Mar 16, 2019 9:41 pm
flboy wrote:That looks expensive... probably better off just to replace Barn Doors with a Ramp door if that is what is needed. Short of replacing the door, I'd just weld some brackets underneath to hold/store some ATV ramps that can be pulled out when needed assuming the Barn Doors are preferred and ramps would just be an occasional use.
Agreed. Takes up a bunch of space to.
The ramp able to dual purpose as a deck outweighs any advantages of barn doors imo.
97 12 valve 4x4 5 speed
rebar
