plywood floor question
I'm curious on opinions about the plywood floor in a cargo trailer.
I am debating how to go about my build.
Should I:
• Remove the ¾ " plywood flooring and seal it with a good primer/sealer ( I was thinking about something like this) https://www.homedepot.com/p/Zinsser-Bul ... /100398391 - then just reinstall this original plywood. Or;
• Remove factory plywood and use "Advantech" subflooring https://www.huberwood.com/advantech/pro ... h-flooring - without any primer/sealer. (I believe this product cannot be painted). This is what the ATC trailer company uses in their trailer floor by the way… Or;
• Install much more expensive "marine grade" plywood (and seal it with something like the product in the first bullet above)
Fyi- I will be insulating the floor from below; with 3" closed cell spray foam- hopefully this in itself will create a water barrier from the bottom side. I am more worried about water getting into the plywood from the top, the edges and through fastener holes.
Thanks in advance for any input!
Should I:
