John61CT wrote:Do you mean the motorcycle(s) are battery powered, or do they have ICEs?
Doesn't work that way. Internally everything works the same internally on DC, the unit just includes circuitry that rectifies the AC input, like a converter / charger.Pinstriper wrote:It does sound to me, however, like a 110v that switches over the 12v once cold and while the generator is off would be your path
RJ Howell wrote:I have a 3.7 cubic foot 3 way frig and on batteries it uses 10.7amps an hour or 256amps in a 24hr period. I use it in propane mode and use .12 (120ma) or 2.88 amps in a 24hr period. I like propane...
onehoser wrote:RJ Howell wrote:I have a 3.7 cubic foot 3 way frig and on batteries it uses 10.7amps an hour or 256amps in a 24hr period. I use it in propane mode and use .12 (120ma) or 2.88 amps in a 24hr period. I like propane...
i'm liking the sound of propane too but it's going to have to be later in my build so that i locate it in the right spot the first time lol! can't be cutting holes all over the place. can you run it on propane while towing? or will it blow the flame out?
tony
troubleScottie wrote:no having one, I doubt it would be recommended to run on propane while driving. Open flame, tip over, extinguishing the flame, propane into cabin to name a few of the problems. Hence the electrical power access.
To that end, you could power the frig/charge your TD battery(s) while driving. Thus counteracting the expenditure. Lots of ideas on how to make this happen.
