I recently bought a 2013 motorhome that I had always planned to buy and pull my cargo trailer with, it has a 4000 watt onan generator with 770 hours I hope that's low hours but I also have a champion 3100 watt wireless remote generator that has a 30amp plugin that I used with my cargo trailer.
My question is do you think it's in my best interest to use both to save or split the wear and tear on the generators ? example use the champion in the day when I can refuel it easily and then at night before I go to bed shut it off and then use the on board generator ?
or am I going to never wear out either so why worry about it.
I was trying to estimate how much gas I would need to run my generators in the summer months when I would be using it the most, the motorhome has a 55gallon fuel tank ? I have heard that the onan burns between a 1/2 to a gallon a hour, my champion would run 5 hours on a gallon of gas when I was running my 8000 btu ac and golf cart charger. 24 hours a day.
This could be a moot point anyway if the champion 3100 watt would not run the motorhome's roof top 1500 AC I am pretty sure they said it was not a 1350 AC.
I haven't been able to use the motorhome yet because of the shut down and am really want to ask before I try something so II don't burn something up ?
I know that it would be worth hauling it around just so I would have a backup incase the motorhome has a generator problem . and I could keep going until I found a repair place ?
just wondering if I am over thinking this ? I guess I will find out when I can get out and start using it ?
