Anyone know about Wilson Sheep Camp campers?
Postby rebar » Sat May 16, 2020 10:21 am
I thought about posting this over in the suspension section, but check this out..
http://www.wilsoncamps.com/index.html
What I find most interesting is the hay wagon steerable configuration.. I did a little research a year ago because a hay wagon has better ground clearance than a conventional trailer, but it didn't belong on the highway imo. But wilson camps seem to have it figured out apparently.
Other than making it difficult to level, are there any major drawbacks to this steerable configuration and any idea how the suspension works? I cant find any close up pictures, but it looks like leaf spring.. And I imagine the steerable front axle isnt available to buy..
Anyway, what do you guys think?
97 12 valve 4x4 5 speed
rebar
Re: Anyone know about Wilson Sheep Camp campers?
Postby tony.latham » Sat May 16, 2020 9:02 pm
You can’t back the original sheep camps. I assume this is no different.
T
Postby hankaye » Sat May 16, 2020 9:52 pm
rebar, Howdy;
I used to live just up the road from these folks a few years ago.
Took a bit of a tour of their place, nice folks.
These you can back-up.
Here's the link;
https://www.wrcamps.com/read-more-about ... amp-models
hank
hankaye
Postby S. Heisley » Sat May 16, 2020 10:15 pm
:thinking: It doesn't look like they have brakes. I wonder how much they weigh.
Postby swoody126 » Sun May 17, 2020 7:57 am
rebar wrote:I thought about posting this over in the suspension section, but check this out..
go look at 2 horse inline trailers
the frames/undercarriages are built super stout and frequently the upper portion will rust out way before the undercarriage is compromised
these undercarriages can be had quite reasonably
they do run on leaf springs and are designed to haul precious(translated EXPENSIVE) horses down the highway at speed
most of them will have side boxes which could be incoorporated into a sheep camp build quite nicely
the stock fenders are usually super tough
with a hitch mounted on the front of your TV(i have one on the front of both my F-350 and my Jeep Cherokee) you can learn to accurately push them backwards w/ little trouble
if you giggle Sheep Camps be ready to be overwhelmed w/ their possibilities
same w/ Vardos
i do have one of these frames and if i live long enough i'll use it under a sheep camp for travel and as an extra bedroom for guests
sw
swoody126
Postby rebar » Sun May 17, 2020 11:49 am
hankaye wrote:rebar, Howdy;
Here's the link;
hank
Interesting..
Did they show you their steerable suspension? Or what's the search term? Can you run it down the highway?
That's what I'm after on this thread, because to me it seems you wouldn't bottom out crossing rough terrain as easily with a wheel at each corner instead of wheels located at the center of the trailer..
swoody126 wrote:go look at 2 horse inline trailers
sw
Vardos Sheep Camps and inline trailers, thanks..
rebar
Postby hankaye » Sun May 17, 2020 8:39 pm
rebar, Howdy;
Here's the link;
hank
Interesting..
sw
As I mentioned before it was awhile ago. Call'em up or email'em. info is on their site.
My Pop always used to say, "If ya have a question, ... go ask an expert." That would be them.
hank
hankaye
