“Semi-Stealth” window AC design
First time posting. Picked up a Cargo Craft V-nose 7x12 cargo trailer couple of weeks ago and have been pondering how to mount a window AC (8000 btu). This is what I came up with. I say semi-stealth because while you can’t see the AC unit from the exterior, the portholes let people know outside something is up I suppose. Kind of strange looking on the exterior, but it works! I insulated the walls and ceiling with 1” Rmax foam board that’s R-6 rated, then finished the walls and ceiling with 9/16” shiplap in addition to the 3/8” plywood that was on the trailer, so it seems pretty well insulated.
Room in the V will be a utility area under the AC hopefully holding the 7 gallon water heater, small 10 gallon water tank and battery, but I worry about all that weight on one side. Opposite the AC/utility closet will be the indoor shower and nature’s head composting toilet. It’s tight, but I think it will all fit.
My wife insisted on a shower with hot and cold water and a decent toilet. It takes up lots of room, but I gotta do what I’m told.
The sleeping arrangements will be a futon we already had. I wanted something not permanently mounted so I can take it out when I need to use it for a cargo trailer again.
https://youtu.be/LxF1U9X3yvM
https://youtu.be/wDR5P48M8IQ
