floor ac
I've been kicking around an idea for mounting the window ac vertically with the butt end in a hole in the floor. this would blow the cool air up into the cargo trailer.
sooo, can anyone give me a good reason with technical explanation as to why not?
the gas from the condensor goes to the compressor and changed into liquid, from there it goes through an orfice to the evaporater turned into a gas
, soaks up heat and then is drawn back into the condensor to repeat the cycle. so why would unit orientation have any ill effects on the function?
