1 PSI is about 27 WC (inches in water column). Sounds like you need a 0.5PSI regulator which is about what a gas grill uses I believe.nsfr1206 wrote:The regulator I purchased for my water heater is a 1 psi regulator. Will this work? My heater calls for 11-14” WC.
