I have to get all the hangers in place and ensure everything is tight and the muffler weep hole is the low point, but this is essentially how it appears underneath the CTC with the intake and exhaust.
featherliteCT1 wrote:I like your new fuel line connector. I had no idea that you could just friction fit a connector into the hole of the tank, held in place by the rubber grommet, with no nut inside the tank.
I guess I thought you were putting the heater into the box,flboy wrote:Have the box screwed down a sealed. Installed latches to hold lid tight against seal. Trying to ensure there will be no C02 seeping back in.
I did buy a Kidde C02 sensore/alarm to mount on wall right above where my head will be when I sleep. I am always a bit cautious about going to sleep in a small area with a combustion furnace. Should not be an issue, but we'll see.
Iv actually been running the heater in the new fifthwheel all month lol I don’t have a logical reason why but…. I’d end up running the diesel heater also to keep the toys warm in the snowflboy wrote:I think you'd like it and you're running diesel anyhow, so you'd just have a spare can on board that you could use for heat or in a pinch if you run out of fuel in your truck.
I definitely support changing it out for thatBigDave_185 wrote:I think you ordered the wrong one
H&B Luxuries Durable Acrylic Dome Dog Window for Fence to View Outside for Satisfying Curious Pets FW058 https://www.amazon.com/dp/B07CXHR9X5/re ... Z5DV1PXY0P
