Are we over thinking insulation
Post on the topic of insulating the floor got me thinking so this may be more of a thought exercise than useful information but here it goes.
How much better at heating and cooling is your trailer with 1,2 or even 3 inches of insulation if you do not also rip your man door apart and insulate it also? You basically have a 2'8" by 6' tall space in your wall that in many cases have less than 1r value of insulation. Also, especially those crazy like me that reframe and put big windows in, what is the r value of the windows.
Your rear doors are usually made of 3/4 plywood which has a whole .9 r value so if you are going to put a lot of insulation on your walls shouldn't you also cover those rear doors?
My theroy is going high R value on our walls is actually a waste of money because there is enough space on our trailer walls that null and void our efforts.
Now ceiling would be the exception to my argument because the sun directly overhead bakes the roof even worse than the walls. Heavy insulation on the roof will help trap the hot air rise in cold weather and create a trap between the baking roof and the interior when trying to cool it down.
Ok poke holes in my thought prosess
