12v/24v charger
12v/24v charger
Postby Splatterman » Fri Sep 06, 2024 8:52 pm
Current set up is 2 12.8 v 200 AH LiFePO batteries in parallel to make a 24v system. My WFCO WF-8955-AD only charges 12v what is the best way to charge this system on shore power? Off grid is charged by solar. :shock:
Splatterman
Re: 12v/24v charger
Postby featherliteCT1 » Sat Sep 07, 2024 5:34 pm
I think you meant to say that your batteries are connected in series to make a 24v battery.
Regardless of whether your battery is 12v or 24v, I like the Victron IP22 charger to charge from 120v shore power. The charger is fully programable.
https://www.victronenergy.com/chargers/blue-smart-ip22-charger
featherliteCT1
Re: 12v/24v charger
Postby Splatterman » Sun Sep 08, 2024 2:53 pm
Yes they are in series is correct but I still don't think a standard 12v charger will work I will definitely look into the victron
Splatterman
Re: 12v/24v charger
Postby tony.latham » Sun Sep 08, 2024 2:57 pm
Out of curiosity, why 24 volts? :thinking:
Re: 12v/24v charger
Postby featherliteCT1 » Sun Sep 08, 2024 4:21 pm
The Victron IP22 charger will charge a 12v or a 24v battery.
featherliteCT1
Re: 12v/24v charger
Postby bdosborn » Sun Sep 08, 2024 5:14 pm
You can get twice as many PV panel watts on a solar controller at 24V versus 12V. It also allows for smaller wires/fuses/breakers/etc. if you are running a larger inverter. I weighed the pros and cons for the van and went 12V. Having a single voltage makes it much easier to cross-connect bits and bobs after a failure in the field.
Images: 806
Re: 12v/24v charger
Postby tony.latham » Sun Sep 08, 2024 6:48 pm
You can get twice as many PV panel watts on a solar controller at 24V versus 12V. It also allows for smaller wires/fuses/breakers/etc. if you are running a larger inverter...
You remind me of Nikola Tesla. :?
Tony :thumbsup:
Re: 12v/24v charger
Postby featherliteCT1 » Mon Sep 09, 2024 6:09 am
Tony[/quote]
Bruce[/quote]
10++ well said!
featherliteCT1
Re: 12v/24v charger
Postby bdosborn » Mon Sep 09, 2024 1:41 pm
Thanks guys!
Images: 806
