Need some advice about my cargo trailer conversion camper. I have a 7 x 16 V-nose trailer and plan to add a 9000 BTU mini split system in the next few weeks. I want to mount the outside condenser unit to the tongue. I do not know how to weld, so I was thinking of creating a small "deck" on the tongue with treated 2 x 6 lumber in order to mount the condenser to it. I already have plenty of treated 2 x 6s and 2 x 8s in my shop, so being able to use those materials would potentially save me some money over trying to find a welder to fabricate a metal structure for it.
The condenser unit weighs about 45 pounds. It is about 24 inches tall, 30 inches wide, and 13 inches deep. I would like to have the upper surface of the "deck" elevated about 20 inches above the tongue so that the condenser does not impede my use of the hand-operated tongue jack. I would fasten the 2 x 6s to the tongue using Teks #12 x 2.75" wood to metal screws (2 screws on the left side of each 2 x 6 and 2 more screws on the other side of each 2 x 6. I would connect the vertical 2 x 6 to the bottom 2 x 6 with structural screws and brackets, then make an "upper deck" consisting of 2 x 8s, fastened to the vertical pieces with brackets and structural screws.
We tend to camp in state and national parks, and 99 % of our travel is on paved roads. The occasional gravel road, but no offroading, so I think this would be robust enough for what I need it to do.
I was thinking of a design like this (not to scale, I know, but hopefully you get the idea).
PS - I already purchased some brackets to mount it to one side of the "V", but I worry about the integrity of those brackets because I can only secure them with 2 screws: one in each steel wall post and wanted to consider something a little sturdier.
Thoughts?
