Back to Bonneville
Back to Bonneville
Postby Modstock » Tue Sep 10, 2024 12:42 am
Went back for World of Speed. This time it was just for fun, no work involved.
This car was driven from AZ and did 163mph, then driven home.
Most race cars are trailered.
Bombshell Betty. Hasn't seen the salt in 9yrs. Was cool to see it in person.
Also got to ride my custom trike on the salt. I've had this since I was 14. It's been hanging on my wall for 15yrs. It needed the brakes finished , I welded up the last few pieces and loaded it in the truck. It's 7ft long so I had to pull the wheels off and spring out of the front fork to get it to fit.
It's a 66 schwinn stingray with a 53 trike axle, extended 6 inches, 1950's 3 speed hub, custom handlbars and extended forks. Raked neck, Tractor seat pan.
Sent from my SM-A115AP using Tapatalk
Modstock
Re: Back to Bonneville
Postby S. Heisley » Tue Sep 10, 2024 5:56 pm
Thanks for sharing your pictures. Glad you had a good time! :thumbsup: :applause:
Postby Modstock » Sat Sep 14, 2024 1:52 pm
Video for the gearheads .
https://youtu.be/VEMAjbSTBSg?si=Iybz2juXy2_dQrNu
Modstock
Postby tony.latham » Sat Sep 14, 2024 5:33 pm
Cool!
How the heck does Bombshell Betty cool her jets, er engine I mean? Not much for airflow coming in.
:thinking: Or does she not run long enough to overheat?
Postby Modstock » Sat Sep 14, 2024 6:39 pm
Alot of these guy's have separate cooling systems with electric pumps and tanks filled with water/ice.
Coolant isn't allowed in any class except the 130 street cars.
I'd like to do a more indepth video on what they do after a run.
Modstock
Postby tony.latham » Sat Sep 14, 2024 10:59 pm
I hope you do. :thumbs-up:
Postby Modstock » Mon Sep 16, 2024 12:34 pm
Part 2 of Saturday's runs.
https://youtu.be/O2aFvN1gtB0?si=EsfzlVwUV5dIh9_7
Modstock
Postby tony.latham » Mon Sep 16, 2024 8:29 pm
Part 2
What were the temps out there? It looks like you could bake a spud on that salt.
Postby Modstock » Tue Sep 17, 2024 12:21 am
Temps weren't that bad, 80's 90's. Could sleep at night with a cool breeze up on the mountain.
Way better than Speedweek. Upper 90's - 105. Hot stale air at night.
Modstock
Postby tony.latham » Tue Sep 17, 2024 11:44 am
:thumbsup: :thumbsup:
Postby Modstock » Thu Sep 26, 2024 1:14 pm
Not my video but shows that the saltflats are shrinking. What used to be 12 miles is now reduced down to 9 and big speeds 450+ may not be achievable anymore.
I missed seeing this car cause we left early due to the explosion.
https://youtu.be/keDxgPsltE8?si=B2Z_ZhJJkvntYahD
Modstock
Postby tony.latham » Fri Sep 27, 2024 6:43 pm
The video didn't explain why it's shrinking. What's the scoop?
Postby KCStudly » Mon Sep 30, 2024 9:38 am
IIRC, there is a mineral extraction operation that is sucking the "life" out of the flats. Consuming the natural resource.
