getting rid of some rust on cast iron.
Re: getting rid of some rust on cast iron.
Postby chezrad » Sun Nov 24, 2013 8:51 pm
Wire brush it with a small brass "toothbrush" is what I would do. Reseason with bacon grease.
chezrad
Images: 24
Postby bobhenry » Mon Nov 25, 2013 8:38 am
Here is a spider skillet I found this Saturday !
I spent about 30 minutes dry sanding it them 30 minutes wet sanding it. Placed it on the gas
stove burner and got it white hot and rubbed on 2 coats of 100% bee's wax.
Dam it lookes good even if I do say so ! Special thanks to Jerry S for the wax tip !
Postby bc toys » Mon Nov 25, 2013 2:57 pm
Slow rust is bad for you better send it over to me j/k sand it with light sand paper or wire brush with brass or get a brass wire cup that go on wireless drill and use it
but after you use it make sure you get all the batter out of the cracks thats where a brass tooth brush come in good
bc toys
Images: 42
Postby bobhenry » Mon Mar 10, 2014 9:01 am
Well a lesson was learned this weekend. While seasoning a new little dutch oven find last weekend I managed to use way to much of the bee's wax. While juggling the hot pan barehanded (DUH) I managed to get about 3 ounces of hot wax on the tile island top and the textured ceramic tile floor. It sets like concrete in about 2 minutes. A bit of scraping and scratching still left a mess in the grout lines and the texture lines. After studying it all week and picking at it it was getting to be a mess. I was talking to the ex and she asked if I still had the steam iron around. Her idea was to set the steam iron on high and place a dripping wet cotton rag over the hardened wax and steam iron it. I would like to report that it works great. The Heat loosened the wax and by sliding the rag around as you "ironed" the tiles the rag picked up the wax leaving no residue. So if you are messy like me simply iron away the spilled wax with a steam iron and an old tee shirt.
Postby GerryS » Mon Mar 10, 2014 9:58 pm
That I got from a guy in the camp inn forum :). Yup...works Great :)
GerryS
Postby the other side » Mon Mar 10, 2014 10:51 pm
Beeswax!!! HUH I'll have to try that!!! Thanks Bob
the other side
Images: 10
Return to Cast Iron
