Waffle Iron, how to clean?
Postby Kevin A » Thu Dec 20, 2007 9:55 am
Kurt (Indiana) wrote:
davefullmer wrote:Mark,
Will the electrolysis take off the black paint?
My Wagner was painted on the outside of the iron as well as the base.
Dave
Dave, I think I'll just try paint stripper or oven cleaner on the base. I did try the electrolysis (for 2 days) but it didn't clean up and well as the other cast iron.
I'll let you know.
Glass Beads :thumbsup: 8)
Kevin A
The other guy
Images: 289
Postby HossHoffer » Thu Dec 20, 2007 4:30 pm
Mark72 wrote:Wow Kurt that thing cleaned up real nice! looks like your base suffers the same affliction as mine. Black paint! I found that cooking spray works really well for reseasoning. Helps get a nice even light coat on the piece especially in the waffling!
Mark :thumbsup:
Mark , the cooking spray is what I've used also. PAM with Olive Oil seems to a good choice.
The cooking spray is a good idea but the olive oil has a very low smoke point plus high solids. Better to go with vegetable oil spray or something with a higher smoke point for initial seasoning. :) Edit: The extra virgin olive oil is a good choice as it is low solids. Check the can.
Hoss
HossHoffer
Images: 7
Postby Kurt (Indiana) » Thu Dec 20, 2007 6:54 pm
Hoss, thanks for the tip. The can says it is made from EVOO so I guess it has low solids.
I don't get a lot of build up on the waffle plates so I suppose the PAM (EVOO) is the right choice.
I also have a "sprayer" for oil which I can use with traditional EVOO.
Thanks for the information. :thumbsup:
CRA2023 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Images: 178
Postby Mark72 » Sat Dec 22, 2007 11:35 am
Sorry for the slow response. I've been down with the stomach thing that is going around. Dave, the easy off worked good on my base.
Mark :thumbsup:
Mark72
Images: 127
Postby Tripmaker » Thu Dec 27, 2007 8:48 am
Kurt (Indiana) wrote:cuyeda, I bought an old Wagner very similar to yours but with long metal handles. Mine has crusted on soot (oil?) from many years of use. This stuff is baked on and is very hard. I decided to leave it on (for character) and it works great as is.
I can vouch for how well Kurt's iron works. His waffles are perfectamundo. :coffee: :thumbsup: :thumbsup: :thumbsup:
Jim
Tripmaker
Images: 59
Return to Cast Iron
