a question about using a do table
Postby NWsage » Sat Jun 28, 2008 3:29 pm
bobhenry wrote:double duty is the creed of a true teardropper. I found out a 12" dutch oven just fits in a 14 1/2 " smokey Joe Junior grill. Works great as a wind screen and while it is not exactly a table it does get the oven off of the ground slightly. And I still got a grill with me too!!
:applause: Good idea!
NWsage
Images: 6
Postby ARKPAT » Sat Jun 28, 2008 7:24 pm
That is a good idea. I have one setting around; now I can put it to work with the Dutch Oven. 8) :thumbsup:
Pat
ARKPAT
Images: 77
Fire Rquirements
Postby HossHoffer » Mon Jun 30, 2008 4:02 pm
Many State and National Parks are starting to require that all fires or flames be 18" above the ground. A good DO table would satisfy that.
HossHoffer
Images: 7
Postby Jim T » Wed Jul 23, 2008 11:50 am
Another good idea I got from Joanne is to use the above mentioned oil pan, and coil a length of roofing tin and set it inside of the pan. You could use a binder clip (from an office supply) to hold the top portion of the tin. A couple of bricks or flat rocks would get it off of the ground, or you could set it on the grill that is available at most camp sites.
Jim
Jim T
Images: 20
Return to Cast Iron
