<img alt="Dutch Oven Table" src="http://www.technoprimitive.org/wordpress/wp-content/uploads/2007/12/camperpixdutch-oven-table.jpg" width="500" height="375" />
Decided to use what I had. Side tables are pieces of a steel shelf I cut. Hot stuff no problem.
<img alt="Side shelf/work surface" src="http://www.technoprimitive.org/wordpress/wp-content/uploads/2007/12/camperpixside-shelfwork-surface.jpg" width="500" height="375" />
Closer view of side shelf. Attached by 6 sheetrock screws from underneath.
<img alt="Cooking surface" src="http://www.technoprimitive.org/wordpress/wp-content/uploads/2007/12/camperpixcooking-surface.jpg" width="500" height="375" />
The cooking surface is old broiler pan tops. I drilled holes at the sides and attached them with screws to the sides of the grill to make sure they will support two full dutch ovens. Openings in bottom of grill allow ashes to fall into a pan on a shelf below.
<img alt="Cooking surface side view" src="http://www.technoprimitive.org/wordpress/wp-content/uploads/2007/12/camperpixcooking-surface-side-view.jpg" width="500" height="375" />
Another view of the cooking surface. 14" Lodge DO just fits.
<img alt="Dutch oven grill fits fine" src="http://www.technoprimitive.org/wordpress/wp-content/uploads/2007/12/camperpixdutch-oven-grill-fits-fine.jpg" width="500" height="375" />
Dutch oven grill fits fine with plenty of room to get past.
